Anthropic brings Asana, Figma, Slack, and more tools directly into Claude as interactive apps
Anthropic Integrates Asana, Figma, Slack, and Additional Tools into Claude as Interactive Apps
Anthropic has unveiled a significant enhancement to its Claude AI model by introducing interactive apps that embed popular third-party tools directly into the chatbot interface. This development allows users to perform complex workflows without switching between applications, marking a step toward more seamless AI-assisted productivity.
The new feature, termed interactive apps, enables Claude to interact natively with services such as Asana for project management, Figma for design collaboration, Slack for team communication, and others including Linear, GitHub, Stripe, and Zapier. Users can now create, edit, and manage content across these platforms entirely within Claude conversations, leveraging the AI’s reasoning capabilities to automate and streamline tasks.
At the core of this integration is Anthropic’s advanced tool use functionality, which has evolved to support dynamic, stateful interactions. Unlike previous static tool calls, interactive apps maintain context over multiple turns, allowing Claude to execute iterative actions such as updating tasks in Asana based on natural language instructions or prototyping designs in Figma through descriptive prompts. For instance, a user might instruct Claude to “review my Figma file and suggest improvements,” prompting the AI to open the file, analyze elements, and apply changes directly.
Pre-built apps are available immediately for select tools, providing ready-to-use entry points. The Asana app lets Claude create projects, assign tasks, update statuses, and generate reports. In Figma, it supports file navigation, object manipulation, layer editing, and prototype testing. Slack integration facilitates message sending, channel management, thread participation, and search operations. Additional apps cover Linear for issue tracking, where Claude can triage bugs, update tickets, and link pull requests; GitHub for repository management, code reviews, and issue handling; Stripe for invoice creation and payment processing; and Zapier for orchestrating multi-app automations.
For power users, Anthropic offers a no-code app builder within Claude’s Projects interface. This tool allows customization without programming expertise: users describe desired functionality in plain English, and Claude generates the app configuration, including authentication, permissions, and action sequences. Developers can further refine apps using the Anthropic API, incorporating custom logic or extending to unsupported services. All apps adhere to strict security protocols, with user-controlled OAuth authentication ensuring data access remains scoped and revocable.
Availability is rolling out to Claude Pro, Max, Team, and Enterprise subscribers on claude.ai and the Claude iOS and Android apps. Team and Enterprise users gain administrative controls for app deployment across workspaces, audit logs for compliance, and integration with single sign-on systems. Early feedback highlights efficiency gains: one beta tester reported reducing context-switching time by 70 percent when managing design handoffs between Figma and Slack.
This launch builds on Anthropic’s prior innovations, such as Artifacts for interactive previews and computer use capabilities for desktop automation. By embedding enterprise-grade tools, Claude positions itself as a central hub for knowledge work, potentially disrupting traditional productivity suites. However, challenges remain, including dependency on tool-specific APIs, potential latency in real-time interactions, and the need for precise prompting to avoid errors in complex workflows.
Anthropic emphasizes ethical considerations, implementing safeguards against unauthorized actions and requiring explicit user confirmation for sensitive operations like financial transactions in Stripe. Future expansions may include more tools and deeper integrations, as hinted in the announcement.
As AI assistants evolve from conversational aids to active workflow participants, this integration underscores a shift toward agentic systems capable of end-to-end task execution. For teams relying on fragmented toolchains, Claude’s interactive apps offer a unified, intelligent layer that could redefine collaboration.
