Anthropic has introduced message threads for the Claude API, a feature that keeps conversation context on the server instead of forcing developers to resend the entire chat history with every request. The company reports that this cuts time-to-first-token by 35 percent for long conversations, making extended interactions noticeably faster.
The change directly targets a common pain point in AI applications. When a user runs a long conversation with a model, every new turn typically requires sending the full history of previous messages. That repetition slows down response generation and drives up token usage. Message threads change that workflow by letting developers create a conversation thread once, then add new messages to that thread as the dialogue continues.
What are message threads?
Message threads are a server-side conversation state. Instead of assembling the full transcript and sending it each time, a developer creates a thread and receives an ID. Subsequent requests in that conversation reference the thread ID and only send the newest user message or turn.
Anthropic designed the feature for long conversations where context matters. For a short single-turn request, the benefits are minimal. But for customer support chats, coding assistants, or agent workflows with many back-and-forth steps, the savings add up quickly.
The result is less repeated input processed by the model. That leads to lower latency and a better experience for end users waiting for a reply.
Why time-to-first-token matters
Time-to-first-token is the delay between sending a request and receiving the first piece of model output. Users notice this wait immediately. A model that feels slow to start its reply can make an application seem sluggish, even if the rest of the response arrives quickly.
For long conversations, this delay used to grow because the model had to process a larger and larger transcript. With message threads, the heavy lifting is done once. The model only needs to handle the new information, keeping the first token fast even as the conversation grows.
Anthropic measured a 35 percent reduction in time-to-first-token for these longer sessions. That is a meaningful improvement for any interactive product built on the Claude API.
For long conversations, the effect is significant: Anthropic measured a 35 percent reduction in time-to-first-token.
What this means for developers
The feature simplifies API integration. Developers no longer need to manually manage conversation history in their own storage and splice it into every request. The thread handles that state in the background.
It also reduces complexity in multi-turn agent loops. Instead of carefully tracking which messages belong to which session, developers can rely on a persistent thread ID.
The implications for cost are also important. Less repeated text sent to the model means fewer input tokens consumed. Lower token count can translate directly into lower API expenses for applications that support long user sessions.
A practical shift for AI applications
Message threads are aimed at production workloads. Chatbots, support tools, and coding assistants are the most obvious candidates. Those applications tend to involve repeated context, long histories, and users who expect quick responses.
By making the server hold the conversation, Anthropic removes much of the overhead that made long chats expensive and slow. The feature lets developers focus on product logic instead of context plumbing.
For teams already using Claude for interactive use cases, the change is straightforward. The thread becomes the central object for the conversation, and each new message is simply appended to that thread.
The performance benefit grows with conversation length. A two-message exchange will not show much difference. A twenty-message support session is where the 35 percent improvement becomes visible.
This is part of a broader push to make AI APIs more practical for real-world applications. Latency and token costs are two of the biggest obstacles to deploying assistants in production. Address both at the same time, and long conversations become much more viable.
Message threads do not change the quality of the model’s answers. They change the speed and efficiency of delivering those answers. For developers running long sessions, that can be the difference between a product that feels instant and one that feels stuck in a loading state.
Anthropic’s approach points to a future where conversational AI handles context more gracefully, with less redundant work on every turn. The 35 percent figure is the headline, but the bigger story is that server-side conversation state is now an official part of the Claude API toolkit.
