Claude Code Now Runs Daily Maintenance on Anthropic’s Software with a 46 Percent Merge Rate
Anthropic’s AI coding assistant, Claude Code, now automatically handles daily maintenance on the company’s own software, achieving a 46 percent merge rate for its pull requests. The tool processes bug fixes, refactors code, and updates dependencies without human intervention.
This shift marks a significant milestone in AI-driven software development. Claude Code is not just a suggestion engine — it is now an active contributor to production systems at Anthropic.
The Lede: What Changed?
Claude Code operates as an autonomous agent within Anthropic’s development pipeline. It runs scheduled maintenance tasks every day, scanning repositories for issues and generating pull requests.
The 46 percent merge rate means nearly half of the AI’s proposed changes are accepted by human engineers without modification. This rate is considered high for automated contributions, reflecting the tool’s growing reliability.
How Claude Code Works
Claude Code is built on Anthropic’s Claude large language model. It has direct access to code repositories, version control systems, and project management tools.
The AI performs three primary functions:
- Bug fixes and patches: Claude Code identifies and resolves software defects, often before they are logged by human developers.
- Code refactoring: It restructures existing code for better performance, readability, or maintainability without changing external behavior.
- Dependency updates: The tool monitors third-party libraries and automatically updates them when security patches or new versions are released.
Each task results in a pull request. Human engineers review the changes and decide whether to merge them.
The 46 Percent Merge Rate Explained
A 46 percent acceptance rate is notable for an AI system operating without human oversight on the generation side. Claude Code does not require a developer to approve its output before creating a pull request.
“A 46 percent merge rate is a strong signal that the AI is producing workable, production-ready code, not just random suggestions.”
Human engineers at Anthropic review every pull request. They reject changes that introduce regressions, fail tests, or do not align with project goals. The acceptance rate reflects a balance between automation and quality control.
Why This Matters for AI in Software Development
Claude Code’s daily maintenance role represents a shift from AI as a copilot to AI as an autonomous engineer. It does not replace human developers but handles repetitive, time-consuming tasks.
For companies adopting AI tools, the implications are clear:
- Reduced developer burnout: Routine maintenance tasks are automated, freeing engineers for higher-value work.
- Faster iteration cycles: Bug fixes and dependency updates happen daily, not weekly or monthly.
- Lower technical debt: Continuous refactoring keeps codebases clean and up to date.
Limitations and Risks
Despite the high merge rate, Claude Code is not infallible. Anthropic reports that some pull requests introduce subtle bugs or fail to account for edge cases.
Human oversight remains critical. The system is not trusted to merge its own changes without review. Engineers must validate AI-generated code against business requirements and security policies.
“No AI system should be given unchecked write access to production code. Human review is not optional — it is the final safety net.”
The Broader Context
Claude Code is part of a growing ecosystem of AI coding agents. GitHub Copilot, Amazon CodeWhisperer, and other tools offer similar capabilities, but few operate at this level of autonomy.
Anthropic’s decision to use Claude Code internally signals confidence in the technology. If the merge rate improves over time, the tool could become a standard component of enterprise development workflows.
