Grok 4.5 is so cheap compared to Fable 5 and GPT 5.5 that benchmark gaps may not matter much
Grok 4.5 Pricing Crushes Fable 5 and GPT 5.5, Making Benchmark Gaps Irrelevant
Grok 4.5 costs dramatically less than Fable 5 and GPT 5.5, according to newly released pricing data. The price difference is so large that even substantial performance gaps on standard benchmarks may not matter for most users.
The key takeaway: cost efficiency, not raw benchmark scores, now defines the practical value of large language models. Grok 4.5 undercuts its closest rivals by a factor of 10 to 20 times on a per-token basis.
The Pricing Breakdown
Grok 4.5 charges $0.15 per million input tokens and $0.60 per million output tokens. This represents a fraction of the cost of both Fable 5 and GPT 5.5.
Fable 5 costs $2.50 per million input tokens and $10 per million output tokens. That is more than 16 times the input cost of Grok 4.5.
GPT 5.5 is priced at $10 per million input tokens and $30 per million output tokens. The input cost alone is nearly 67 times higher than Grok 4.5.
Cost advantage of Grok 4.5: for the price of one call to GPT 5.5, you can run more than 60 calls to Grok 4.5 with the same input volume.
Benchmark Gaps in Context
Standard benchmarks like MMLU, HumanEval, and GSM8K show Grok 4.5 trailing Fable 5 and GPT 5.5 by 5 to 15 percentage points. However, these differences shrink dramatically when you consider real-world usage patterns.
Real-world tasks often do not require the top 1% of benchmark performance. A model that scores 85% on a reasoning test versus 95% still delivers highly useful results for most applications.
The marginal utility of a benchmark point decreases sharply once a model passes a certain competence threshold. Grok 4.5 clears that threshold for a vast range of common use cases.
Why Price Matters More Than Benchmarks
Cost determines scalability. A startup or enterprise deploying AI at scale will burn through budgets quickly if they pay 10x or 50x more per token. Grok 4.5 allows for massive parallel inference without budget blowout.
Latency and throughput also improve with lower cost. Cheaper models can be run on more instances, enabling faster responses and higher concurrency.
Accessibility expands dramatically. Developers and researchers with limited budgets can now experiment with a state-of-the-art model without prohibitive expenses. This democratizes AI in a way that benchmark scores never could.
The Caveats
Grok 4.5 is not the best model for every task. Highly specialized domains like advanced mathematics, code generation with complex logic, or nuanced creative writing may still benefit from the extra performance of Fable 5 or GPT 5.5.
Benchmark validity is under scrutiny. Many benchmarks are leaked into training data, making absolute scores less reliable. Real-world performance is what ultimately matters.
Quality differences become visible at the edges. For tasks requiring near-perfect accuracy or deep reasoning, the premium models may still be worth the extra cost.
Grok 4.5 shifts the conversation from “which model is best” to “which model is best for the price.” The answer for most users is now clearly Grok 4.5.
Companies and individual developers should evaluate their own use cases. If a task does not require the absolute top benchmark score, the cost savings from Grok 4.5 are too large to ignore.
