About the Issues and Help category
Hi everyone,
I’m Mark and I’m facing an issue with [briefly and clearly state the problem you’re encountering].
Best, if you add an screenshot.
[Optional: Briefly describe the steps you’ve already taken to try and resolve the issue.]
I’m hoping someone in the community might have encountered a similar problem or have some helpful advice on how to proceed. Any suggestions or guidance would be greatly appreciated.
Thanks in advance for your help!
Best, Mark!
Tips for a helpful “Issues and Help” post:
  • Be specific: The more details you provide about the issue, the better equipped others will be to assist you.
  • Be clear and concise: Use clear and easy-to-understand language to describe the problem.
  • Search for existing threads: Before posting, do a quick search of the forum to see if a similar issue has already been discussed.
  • Be patient and polite: Remember that everyone is volunteering their time to help. Be patient and polite in your interactions with other members.
I hope this helps! Feel free to adapt this template to fit your specific situation.
