AI reasoning models think harder on easy problems than hard ones, and researchers have a theory for why
AI Reasoning Models Expend More Effort on Easy Problems: Researchers Propose a Novel Explanation
Recent advancements in large language models (LLMs) have introduced sophisticated reasoning capabilities, particularly through models designed for extended “thinking” processes. Models such as OpenAI’s o1-preview, o1-mini, DeepSeek’s R1, and Anthropic’s Claude 3.5 Sonnet exemplify this trend by generating chains of thought or internal deliberations before delivering final answers. However, empirical analysis reveals a counterintuitive behavior: these models allocate disproportionately more computational effort—measured in terms of inference time or token generation—to simpler problems compared to more challenging ones.
This phenomenon, dubbed “reverse difficulty scaling,” challenges conventional expectations. In human cognition, easier tasks typically require less mental exertion, while difficult ones demand greater focus. Yet, for AI reasoning models, the opposite holds true across diverse benchmarks. Researchers from institutions including Stanford University, ETH Zurich, and the University of Oxford conducted a comprehensive study, analyzing performance on mathematical reasoning tasks from datasets like GSM8K and MATH. Their findings indicate that models consistently spend longer processing easy problems, with inference times sometimes exceeding those for hard problems by significant margins.
To quantify this, the team plotted inference time against problem difficulty, where difficulty was defined by the percentile rank of accuracy across a held-out evaluation set. For instance, on GSM8K—a grade-school math dataset—o1-preview exhibited peak inference times on problems in the 20th to 40th percentile of difficulty, rather than the most challenging ones above the 80th percentile. Similar patterns emerged for o1-mini and DeepSeek-R1, with Claude 3.5 Sonnet showing milder but still noticeable effects. Even when normalizing for output length, the trend persisted, suggesting that the extra time stems from extended internal reasoning steps rather than verbose final responses.
This observation holds across problem types, including multi-step arithmetic, algebra, and even non-mathematical domains like symbolic manipulation. The researchers ruled out trivial explanations, such as models generating unnecessarily long chains of thought for easy problems. Instead, they observed that reasoning traces for simple tasks often include redundant verifications or explorations of alternative paths that ultimately converge quickly but consume extra compute.
Unpacking the “Peak Log-Probability Hypothesis”
To explain this anomaly, the researchers propose the “peak log-probability hypothesis.” This theory posits that the internal probability distributions generated by the model during reasoning play a pivotal role. Specifically, easy problems tend to exhibit sharper “peaks” in the log-probability landscape of potential solutions. The maximum log-probability of the correct answer is higher for straightforward problems because the model’s pre-training aligns more closely with common patterns encountered in training data.
During test-time compute—where models engage in search-like processes akin to Monte Carlo Tree Search (MCTS) or best-of-N sampling—these high-probability peaks influence exploration dynamics. For easy problems, the model quickly identifies a highly confident path but continues to sample and evaluate nearby alternatives due to the steep probability gradients. This leads to broader search trees and more nodes expanded before convergence, inflating compute usage. In contrast, hard problems feature flatter probability distributions with lower peak log-probabilities, prompting the model to prune exploration earlier as no dominant path emerges, thus conserving resources.
The hypothesis was tested by perturbing the models’ outputs. When artificially flattening the log-probability peaks for easy problems (via temperature scaling or logit adjustments), inference times decreased, aligning more closely with expected scaling. Conversely, sharpening peaks on hard problems increased their processing time. These interventions provide causal evidence supporting the theory.
Implications for Model Scaling and Optimization
This discovery has profound implications for the development of reasoning models. Traditional scaling laws assume monotonic increases in compute with task difficulty, but reverse difficulty scaling suggests inefficiencies in current architectures. Optimizing for compute optimality—where effort scales appropriately with difficulty—could yield substantial gains. For example, dynamically adjusting search parameters based on early log-probability estimates might prevent overthinking on easy tasks.
The study also highlights limitations in current evaluation practices. Benchmarks often average performance without accounting for per-instance compute, potentially masking inefficiencies. Future assessments should incorporate compute budgets, rewarding models that allocate resources judiciously.
Moreover, the findings extend to frontier models’ training paradigms. Techniques like process supervision, which reward intermediate reasoning steps, may inadvertently reinforce peak-driven exploration. Refinements could involve curriculum learning that balances easy and hard examples to calibrate probability distributions.
Broader Context in AI Reasoning Research
This work builds on prior observations of test-time compute scaling. Earlier models without explicit reasoning, like GPT-4o, showed mild reverse scaling, but it intensifies in dedicated reasoning systems. The researchers speculate that reinforcement learning from human feedback (RLHF) or outcome-based training amplifies the effect, as models learn to over-verify confident predictions to minimize errors.
Comparisons across providers reveal nuances: OpenAI’s o1 series displays the most pronounced reverse scaling, while DeepSeek-R1 shows more balanced allocation. These differences likely stem from variations in search algorithms and base model capabilities.
In summary, the peak log-probability hypothesis offers a parsimonious explanation for why AI reasoning models “think harder” on easy problems. By addressing this quirk, developers can pave the way for more efficient, human-like reasoning systems. The full study, including code and datasets, is available on GitHub, inviting further experimentation.
