Alibaba’s open-weight Qwen3.8-Max takes on long-horizon AI tasks with 2.4 trillion parameters
Alibaba’s Qwen team has released Qwen3-8 Max, an open-weight Mixture-of-Experts (MoE) model with 2.4 trillion total parameters (8 billion active). The model is designed to excel at long-horizon tasks that require complex reasoning, multi-step planning, and sustained tool use.
It is available under the Apache 2.0 license, allowing commercial deployment and modification.
## Model Architecture and Scale
Qwen3-8 Max uses an MoE architecture with 2.4 trillion total parameters, but only 8 billion are active per forward pass. This balances high capability with manageable computational cost.
The model supports a context window of up to 128,000 tokens. It can generate up to 8,000 tokens of internal reasoning before producing a final answer.
“The model is trained with reinforcement learning from human feedback (RLHF) to produce long chains of reasoning, making it ideal for tasks that require sustained logical deduction.”
## Performance Benchmarks
Alibaba reports that Qwen3-8 Max outperforms GPT-4o and DeepSeek R1 on several difficult benchmarks. These include GPQA (graduate-level science questions), AIME (math problem solving), and MATH (advanced mathematics).
On the LongBench-v2 evaluation, which tests long-context understanding, the model also achieves leading scores. It demonstrates strong results on tool-use benchmarks such as BFCL and SWE-bench.
The model is particularly strong in scenarios requiring multi-step reasoning, such as complex code generation, mathematical proofs, and strategic game playing.
## Open-Weight Implications
Open-weight release under Apache 2.0 means developers can download, fine-tune, and deploy the model without per-seat licensing fees. This contrasts with closed models like GPT-4o or Claude.
  • Commercial use permitted without additional royalties or usage caps.
  • Local deployment possible on high-end GPUs (e.g., A100 or H100) for privacy-critical applications.
  • Fine-tuning flexibility allows customization for domain-specific long-horizon tasks (e.g., scientific research, robotics planning).
The model is available via Hugging Face and Alibaba’s ModelScope platform.
## Technical Details
Qwen3-8 Max employs a dense-to-MoE training strategy. The base model is initially trained as a dense transformer, then converted to MoE with expert layers.
  • Expert routing uses a Top-2 gating mechanism, activating only two experts per token.
  • Training data includes a curated mix of code, math, science, and multilingual text.
  • Optimization includes group relative policy optimization (GRPO) for extended reasoning chains.
The model is part of Alibaba’s broader Qwen3 family, which also includes smaller variants ranging from 0.5B to 30B parameters.
## Use Cases and Limitations
Ideal applications include complex code debugging, multi-step math proofs, long-form document analysis, and autonomous agent workflows.
Limitations remain: the model requires significant hardware for local inference (at least 16GB VRAM for quantized versions). It may also exhibit occasional over-reasoning on simple tasks.
For developers, this open-weight release lowers the barrier to building AI agents that execute extended sequences of actions or reasoning.
