Anthropic Developer’s Prompting Tips Focus on Identifying Your Own Blind Spots First
The most effective way to improve AI outputs is to first examine your own assumptions and cognitive gaps, according to a developer from Anthropic. In a new guide for prompting Claude (code-named Fable 5), the developer argues that many prompt failures stem from the user’s unconscious biases, not the model’s limitations. The key takeaway: before you tweak the prompt, audit your own blind spots.
“The model will faithfully reflect the gaps in your reasoning if you don’t flag them,” the developer warns. “Your first job is to write a prompt that exposes what you might be missing.”
Why Blind Spots Matter More Than Prompt Syntax
Most prompting guides emphasize wording, structure, or formatting. Anthropic’s approach turns that upside down. The developer claims that the single biggest variable in prompt quality is the user’s own knowledge limits. If you ask a question without realizing you’ve omitted a critical constraint, the model will fill the gap with its (often wrong) default assumptions.
Critical insight: A model is only as good as the problem you define. If your definition is incomplete, no amount of “please think step-by-step” will save you.
Three Steps to Find and Fix Your Blind Spots
The developer outlines a practical routine that forces self-audit before any prompt iteration.
Step 1: Write a “Devil’s Advocate” Counter-Prompt
After drafting your initial prompt, immediately write a second prompt that argues the opposite position or questions your assumptions. For example, if you’re prompting Claude to write a business plan, ask it to “list the top five reasons this plan will fail.” The goal is to surface hidden weaknesses you didn’t consider.
- Identify your strongest confidence: The thing you are most sure about is often the place where your blind spot is largest.
- Check for omitted constraints: Ask “What information have I deliberately or unconsciously left out?”
- Force a contradictory answer: Let the model argue against you. The flaws in its counter-argument are often flaws in your original framing.
Step 2: Run a “Blind Spot Audit” Before Any Prompt Changes
Instead of tweaking the prompt immediately, pause and list three things you assume to be true that could be false. The developer emphasizes that this step is non-negotiable.
Developer’s tip: “If you change the prompt every time the output doesn’t match your expectations, you are just training the model to agree with your error. Break that cycle by auditing yourself first.”
Step 3: Use the Model as a Reflective Mirror
Once you’ve identified potential blind spots, feed them back into the prompt as explicit instructions. For example, if you realize you assumed a certain market size, add: “Do not assume the market is growing. Instead, verify my assumption and challenge it if data contradicts it.”
- Explicitly define your biases: “I tend to overestimate X. Please correct me if I do.”
- Ask for multiple perspectives: “Generate three versions: one optimistic, one pessimistic, and one neutral.”
- Demand evidence for the model’s own claims: “Only answer if you can cite a source. If not, say you don’t know.”
Real-World Example: From Generic to Self-Aware Prompting
The developer shares a before-and-after scenario. A user prompts Claude to “write a marketing plan for a luxury water brand.” The output is generic and dull.
After a blind-spot audit, the user realizes they assumed “luxury water” meant premium packaging and high price — but never considered target audience, distribution channel, or brand ethos. The revised prompt reads:
“Write a marketing plan for a luxury water brand sold exclusively in five-star hotels. Do not assume affluent customers. Instead, assume the buyer is a sustainability-conscious traveler who values glass bottles over plastic. Challenge my assumption that ‘luxury’ equals ‘expensive’ — find a cheaper alternative that still feels premium.”
The resulting output is specific, nuanced, and actionable.
Ruthless Self-Questioning Beats Prompt Engineering Tricks
The developer concludes that most prompt “hacks” are band-aids for unexamined assumptions. The real skill is learning to question your own question. In practice, this means:
- Spending 80% of your prompt design time on self-audit.
- Using the model to reveal your blind spots, not just to generate answers.
- Treating every poor output as a symptom of your own incomplete reasoning.
Bottom line: If you want Claude (or any AI) to be smarter, start by being smarter about what you don’t know.
