Anthropic gives METR inside access to audit its AI models and safety practices
Anthropic Opens Its Models to METR for Independent Safety Audits
Anthropic has granted METR, a nonprofit AI safety research group, inside access to audit its models and safety practices. The arrangement lets external evaluators examine AI systems from within rather than testing them through public interfaces.
The move positions Anthropic as one of the first frontier AI labs to offer this level of third-party scrutiny.
What METR Will Examine
The audit covers model development and the safety procedures designed to contain dangerous capabilities. METR can now assess systems while they are being built, tested, and prepared for release.
  • Model evaluation access: METR will test Anthropic’s models directly at various stages of development.
  • Safety practice review: The group can inspect internal protocols for handling high-risk AI behaviors.
  • Deployment decision insight: Auditors gain visibility into the criteria that determine when a model reaches the public.
Why Anthropic Is Doing This
Anthropic has consistently argued for external oversight of frontier AI. Its leadership believes no AI developer should be the sole judge of its own safety efforts.
Granting inside access to an independent group transforms that rhetorical commitment into a structural one.
METR’s Track Record
METR evolved from the Alignment Research Center’s evaluation arm. The group is known for field-testing advanced AI systems and identifying capabilities that could pose safety risks.
Its previous work focused on measuring models from multiple developers. The shift from black-box testing to inside access gives METR a much clearer picture of what occurs behind the scenes.
The core value: independent evaluators no longer have to guess what happens inside a lab. They can see it.
How This Differs From Standard Evals
Most AI companies run external evaluation programs where researchers submit prompts to a published model. That approach reveals output behavior but hides the internal safety mechanisms shaping it.
Inside access removes that barrier. METR can observe the safety architecture directly, including guardrails, stress limits, and how failures are prevented or mitigated.
What It Means for the Industry
This decision puts pressure on other AI developers. If Anthropic can welcome independent auditors, rivals will face tougher questions about their own closed practices.
The arrangement also serves as a test case. It demonstrates whether meaningful external oversight can function alongside rapid commercial deployment.
The Limits of the Deal
Access is not the same as control. METR can observe and report, but it lacks enforcement authority over Anthropic’s final decisions. Its recommendations must carry influence through credibility and public trust.
There is also the question of scope. Access terms can always be restricted by the company that controls them. The durability of the arrangement depends on continued goodwill from both sides.
The key limitation: visibility improves oversight, but it does not guarantee that recommended changes will be implemented.
The Signal
Anthropic’s decision is a bet that transparency can build trust in an industry marked by opaque practices. It comes at a time when governments and civil society groups increasingly demand independent checks on AI development.
The partnership is worth watching. If it works, it may become a model for cooperation between AI labs and external evaluators. If it does not, it will serve as a lesson on the limits of voluntary oversight in an era of powerful machines.
