Anthropic tested Zhipu AI’s open-weight GLM-5.3 model against its own “Mythos” preview. The test measured the ability to generate cyber exploits. GLM-5.3 nearly matched Mythos.
This result shifts the open-weight debate from theory to practice. A publicly available model almost equals a specialized red-teaming tool.
The Red Teaming Benchmark
Anthropic built the Mythos preview to test worst-case scenarios. It represents the outer limit of Claude’s offensive capabilities.
The company expected Mythos to be unique. It is not. Zhipu’s general-purpose model performed nearly as well on exploit generation.
“This confirms our fears about the rapid capabilities of open-weight models,” Anthropic stated.
Key Findings from the Test
- Model tested: Zhipu AI’s GLM-5.3.
- Comparison model: Anthropic’s proprietary Mythos preview.
- Test type: Exploit generation benchmark.
- Result: GLM-5.3 nearly matched Mythos.
The Access Control Problem
The main difference is not capability. It is access.
Mythos is strictly internal. It cannot be downloaded or modified.
GLM-5.3 is an open-weight release. Anyone can download it and remove restrictions.
Access makes the dangerous capability real. A less capable but widely available model can be more harmful than a locked-away supermodel.
Arguments in the Debate
This finding fuels two opposing views.
Critics of open-weight models use this as proof that releases are too risky. They want strict capability thresholds based on tests like this.
Proponents of open-weight models argue that transparency enables safety research. They say restricting access creates a knowledge monopoly.
Anthropic clearly sides with the critics. The company has long warned about open-weight risks. This test gives it hard data to support the warning.
Zhipu AI’s Response
Zhipu AI rejected the alarming interpretation. The company says GLM-5.3 is a general-purpose model and not designed for malicious use.
Zhipu pointed to its own safety alignment work. It argued that capability benchmarks do not predict real-world misuse.
The company also suggested that open models help the global community study AI risks. Transparency and collective oversight are the better path.
Implications for Policy
Regulators now have a concrete case study. The EU AI Act and US Executive Orders try to classify risky models.
This test shows exactly where the line sits. Open-weight models can cross the threshold of dangerous dual-use capability.
Future models will only be more capable. This benchmark is a leading indicator for the policy challenges ahead.
Consequences for Cybersecurity
The exploit generation test is highly relevant to cybersecurity. It measures a concrete offensive capability.
Open availability of this capability changes the threat landscape. Companies and governments must adjust their defensive postures.
The gap between proprietary and open models is closing in a high-stakes domain. The industry must respond to the evidence.
A Warning for the Future
The speed of this development is worrying. GLM-5.3 did not take years to catch up to proprietary models.
If this trend continues, open-weight models will surpass proprietary red-teaming tools. The policy window for action is closing fast.
