Anthropic slashes Claude Fable 5 limits in Max and Team Premium and pushes Pro users toward API pricing
Anthropic Slashes Claude Pro Limits, Pushes Max and Team Users Toward API Pricing
Anthropic has significantly reduced the free usage limits for its Claude chatbot across all paid tiers, including Max and Team plans, effectively steering heavy users toward its API pricing model. The changes took effect immediately for new users and will roll out to existing subscribers in the coming weeks.
Who it affects: All paying Claude subscribers on the Pro, Max, and Team plans. What changed: Usage caps were cut by roughly half for Max and Team tiers, and by over 60% for Pro users. Why: Anthropic cites “abuse” by a small number of users consuming excessive resources, but the move aligns with a broader strategy to monetize high-volume usage through per-token API billing.
New Usage Limits by Tier
Pro plan ($20/month): Users now get approximately 45 messages every 8 hours, down from the previous 100-message cap. This represents a 55% reduction. Anthropic also removed the “occasional” 5x usage boost previously available during low-traffic periods.
Max plan ($100/month): The cap dropped from 300 messages per 8 hours to just 100. Overnight usage (previously unlimited) now counts toward this limit. The “occasional” 5x boost was also eliminated.
Team plan ($30/user/month): Each user now receives 100 messages per 8 hours, halved from the prior 200-message limit. The 5x boost is gone.
Key Warning: Heavy users who previously relied on unlimited overnight access will face the most disruption. All usage now counts toward a single, lower cap.
The API Push
Anthropic is explicitly directing power users toward its API pricing, where they pay per token rather than a flat monthly fee. The company states that users who regularly hit the new limits “may benefit from switching to the API for more flexible, usage-based pricing.”
This strategy mirrors moves by OpenAI, which similarly reduced ChatGPT Plus limits in 2024 before introducing higher-priced Pro tiers. Anthropic’s message is clear: flat-rate plans are for casual use; heavy use must go through the API.
Background and Context
Anthropic introduced the Max plan in early 2025 as a “high-usage” alternative to the Pro tier. At launch, it promised “at least 5x the usage limits of Pro” and unlimited overnight access. The new limits erase that advantage, making Max roughly equivalent to the old Pro cap.
The company says the changes target “a small number of users” who accounted for “a disproportionately large share of total usage.” However, no data on how many users this affected has been shared.
Industry observers note that AI model inference costs remain high, especially for long-context conversations. Claude’s 200,000-token context window makes it resource-intensive. Anthropic likely needs to curb costs as it scales infrastructure for its next-generation models.
What This Means for Users
Casual users on the Pro plan may not notice the change if they send fewer than 45 messages daily. Power users on Max or Team plans will likely hit their new caps within a few hours of active work. Businesses using Team plans must consider whether per-user limits justify the subscription cost versus adopting API billing.
Anthropic has not announced grandfathering for existing subscribers. All users will see the new limits within weeks, regardless of plan renewal date.
Bottom Line: If you use Claude for more than a few hours of conversation per day, expect to either upgrade your workflow to the API or significantly reduce your usage.
