Anthropic wants to do for physical hardware what its Model Context Protocol did for software
Anthropic wants to do for physical hardware what its Model Context Protocol (MCP) did for software. The company aims to create a standard that lets AI agents control devices, robots, and industrial equipment as easily as they currently handle databases and APIs.
This new push targets the physical world. The goal is to allow AI models to interact with hardware systems through a unified, open protocol. It mirrors how MCP standardized connections between AI and software tools.
What is the proposed hardware protocol?
The protocol would act as a universal translator. It sits between an AI model and any piece of hardware, translating human commands into machine actions.
It standardizes commands for movement, sensor reading, and data output. This means a developer could write one instruction set that works across a robot arm, a drone, or a factory sensor.
Anthropic argues that current hardware integration is fragmented. Each device requires custom code, drivers, or middleware. The new protocol aims to eliminate that friction.
Why is this a direct response to software success?
Anthropic’s Model Context Protocol became a de facto standard for connecting AI to software. It replaced dozens of competing integration libraries.
The same problem exists in hardware. Companies like NVIDIA and Siemens already push proprietary systems. Anthropic wants an open alternative that any manufacturer can adopt.
“We believe that the biggest bottleneck in AI robotics is not the model, but the lack of a common language between AI and hardware.” - Implied reasoning from the article.
What are the immediate use cases?
The protocol targets three main areas:
Industrial automation involves coordinating robotic arms, conveyor belts, and safety sensors using natural language commands from a single AI controller.
Consumer robotics focuses on allowing home robots to operate vacuum cleaners, door locks, and kitchen appliances through a unified interface.
Healthcare equipment benefits from connecting infusion pumps, diagnostic scanners, and patient monitors to an AI that can adapt to changing patient needs.
Each of these applications currently requires bespoke software development. The protocol promises to reduce that to a plug-and-play setup.
What are the challenges and risks?
Security is the primary concern. A hardware protocol that controls physical machinery must be immune to exploits. A corrupted command could cause physical damage or injury.
Latency requirements vary wildly. A robotic arm needs millisecond response times. A weather sensor can tolerate seconds. The protocol must handle both extremes without compromise.
Adoption faces a chicken-and-egg problem. Hardware manufacturers hesitate to support a protocol without widespread AI adoption. AI developers hesitate to invest without hardware support.
Who else is working on this problem?
Several companies target this space. NVIDIA’s Isaac platform and Siemens’ Industrial Edge offer proprietary alternatives. Neither is open.
The open-source community has ROS (Robot Operating System), but ROS is complex and requires specialized engineering.
Anthropic’s approach is unique because it prioritizes simplicity. It asks: what is the absolute minimum interface needed for an AI to control a physical machine?
What is the expected timeline?
Anthropic has not released a public timeline or documentation. The report suggests this is an early-stage initiative, likely in the research and prototyping phase.
However, the company has a track record of shipping. MCP went from concept to widespread adoption within 18 months. Analysts expect a similar cadence for hardware.
Beta testing may begin within 12 months, targeting industrial partners with existing robotics infrastructure.
Bottom line
Anthropic bets that the same “protocol wins” strategy that dominated software will work in hardware. If successful, it could collapse the cost and complexity of industrial robotics.
If it fails, it joins a long list of attempts to unify the physical world with AI. The outcome depends entirely on adoption by manufacturers and developers.
