Anthropic’s Fable 5.2 now completes 41 percent of real freelance jobs, up from 2.5 percent a year ago. The leap shows AI can handle a substantial share of paid, practical work.
A year ago, almost no tasks were finished without human help. Now, more than four in ten are.
The Numbers
- The current completion rate is 41 percent. Fable 5.2 finishes a large share of real freelance jobs.
- The rate one year ago was 2.5 percent. The gap is a 16-fold increase.
- The evaluation uses real jobs. This is not a lab-style test.
A jump from 2.5 percent to 41 percent is one of the strongest signs yet that AI agents are moving from helpers to doers.
What Changed
The comparison matters because it tracks the same type of work over time. Last year, AI could barely start most freelance jobs. Today, it can complete a much larger share.
The scale of progress is the main story. More jobs are being finished at a level that matches what a client would accept.
Completing a job means moving from instructions to a finished outcome. That makes Fable 5.2 more than a simple helper.
What This Means
For anyone hiring freelance help, the number is a sign that AI can handle more tasks. The share is high enough to change how small jobs are assigned.
For freelancers, the trend is more challenging. AI is now taking a share of work that used to require human attention. The rate is likely to keep rising.
For researchers, the result is a clear baseline. It shows how far agentic AI has come in one year.
The Limit
The same number also exposes a clear limit. A 41 percent completion rate means 59 percent of real freelance jobs still need humans.
The remaining tasks are probably harder. They may require judgment, context, or back-and-forth communication. Current systems cannot reliably handle that.
The 59 percent is the part of the story that should not be ignored. AI is strong, but it is not a full replacement.
Why It Matters
The jump from 2.5 percent to 41 percent is not a small step. It is a structural shift. One year is a short time in technology.
If the pace continues, the next report could look very different. The old assumption that AI cannot do real freelance work is already outdated.
The new figure also sets a tougher standard for future systems. Anything that wants to beat this number will have to complete more real jobs than Fable 5.2.
Bottom Line
Anthropic’s Fable 5.2 completes 41 percent of real freelance jobs. That is up from 2.5 percent a year ago. The progress is real and measurable.
The system is not perfect. Most jobs still require humans. But the direction is clear and the pace is fast.
AI has moved from a minor player in freelance work to a serious one. The next year will show whether the trend continues.
