Apple Researchers Uncover Fragility in AI Controllability Across Models and Tasks
A recent study from Apple Machine Learning Research has exposed significant limitations in the controllability of large language models (LLMs). Titled “Controllability in Text Generation,” the paper demonstrates that efforts to steer AI outputs through techniques like representation engineering often fail unpredictably. Controllability, the ability to guide model behavior toward desired attributes such as reduced toxicity or specific sentiment, proves fragile, with performance fluctuating wildly depending on the task, model, and even minor prompt variations.
The researchers evaluated 14 open-weight LLMs, ranging from 1.5 billion to 70 billion parameters, including models like Llama 3, Mistral, Gemma 2, and Qwen. They also tested four proprietary models: GPT-4o, Claude 3.5 Sonnet, Gemini 1.5 Pro, and o1-preview. To assess controllability, the team employed representation engineering, a method that identifies and manipulates internal “steering vectors” within the model’s hidden states. These vectors represent directions in activation space corresponding to traits like sentiment (positive or negative), toxicity, or bias (e.g., gender or age stereotypes).
The study focused on five key tasks: sentiment control, toxicity reduction, refusal behavior, sycophancy mitigation, and bias alignment. For each, baseline model outputs were generated from prompts drawn from datasets such as ToxiGen for toxicity and BOLD for bias. Steering vectors were then computed by contrasting activations from positive and negative examples, scaled and added back to influence subsequent generations.
Results revealed stark inconsistencies. On sentiment control, for instance, Llama 3 70B achieved near-perfect positive steering (96% success) but faltered on negative sentiment (only 12%). Mistral Nemo excelled at toxicity reduction (85% success) yet performed poorly on refusals (under 20%). Proprietary models showed mixed outcomes: Claude 3.5 Sonnet led in toxicity control (92%), while GPT-4o topped sycophancy reduction (88%). However, no model dominated across all tasks, and open models generally lagged behind closed ones.
A core finding was the phenomenon of “representation collapse,” where steering vectors lose efficacy after just a few applications. Initial successes degraded rapidly; for example, repeated positive sentiment steering on Gemma 2 9B dropped from 90% to below 50% after five iterations. This collapse varied by task: sentiment vectors decayed slower than toxicity ones, highlighting task-specific vulnerabilities.
Prompt sensitivity amplified these issues. Altering a prompt by adding innocuous phrases like “Please reason step by step” could swing controllability from 90% to 10%. The study tested 10 prompt variants per task, finding success rates varying by up to 80 percentage points. This brittleness persisted across models; even top performers like o1-preview saw drops of over 50% in some cases.
The researchers also examined vector universality. Steering vectors trained on one model rarely transferred effectively to others, with cross-model success rates averaging below 30%. Within-model transfer across tasks fared slightly better but still averaged 45%, underscoring a lack of robust, generalizable control mechanisms.
Further analysis linked controllability to model architecture and training. Instruction-tuned models outperformed base models, suggesting fine-tuning enhances steerability. Larger models trended toward better average performance, yet exceptions abounded: Qwen 2.5 14B outperformed bigger siblings on bias tasks. Compute-optimal scaling did not guarantee control; some smaller models matched giants on specific metrics.
The paper raises critical implications for AI safety and alignment. Current steering methods, while promising, cannot reliably enforce behaviors in deployment scenarios with diverse prompts or iterative use. Fragility undermines applications like content moderation or personalized assistants, where consistent control is paramount. The authors advocate for developing more robust techniques, such as multi-vector steering or architectural changes to preserve representations over sequences.
In experiments, the team controlled for confounders like prompt leakage by using held-out datasets and normalizing vectors to unit length. They reported metrics including success rate (binary alignment with target), mean and worst-case performance, and rank correlation across prompts. Code and vectors are available on GitHub, enabling replication.
This work challenges optimistic views of LLM steerability, revealing it as an unreliable patch rather than a solved problem. As AI systems scale and integrate into real-world tools, addressing these controllability gaps becomes urgent for trustworthy deployment.
