Authors Guild test finds some AI detectors perfectly identify human writing while others fail on every single text
AI Detectors Reveal Deep Flaws: Some Perfectly Identify Human Writing, Others Fail Completely
The Authors Guild has published a test that exposes stark performance gaps among popular AI detection tools. GPTZero and Originality.ai correctly identified every single human-written text, while two other detectors flagged all ten human submissions as AI-generated. This means authors and publishers relying on these tools risk falsely accusing human writers of cheating.
The test used ten short, unpublished texts from Authors Guild members. Each detector analyzed the same set, and the results were striking: success rates ranged from 0% to 100%. The findings underscore the unreliability of current AI detection technology.
The Test and Its Setup
The Authors Guild, a professional organization for writers, designed a simple benchmark. They collected ten human-authored pieces — all original, never published, and ranging from essays to fiction. No AI-assisted text was included. The goal was to measure false-positive rates, not the ability to catch AI-generated content.
The detectors tested included GPTZero, Originality.ai, and two widely used commercial tools that the Guild did not name publicly. Each tool analyzed the same ten texts under identical conditions.
Results: Success and Failure at Both Extremes
  • GPTZero scored 100% accuracy, correctly labeling all ten texts as human-written.
  • Originality.ai also achieved 100% accuracy on the same set.
  • Detector A flagged every single human text as AI-generated, a 0% success rate.
  • Detector B similarly marked all ten as machine-written.
  • Another unnamed tool was inconsistent, correctly identifying about half the texts.
The Guild noted that the two failing detectors produced “false positives on every text,” making them useless for vetting human work. In real-world scenarios, such tools could lead to unjust accusations of plagiarism or dishonesty, especially against freelance writers, students, and journalists.
Implications for Writers and Publishers
The test highlights a critical risk: reliance on AI detectors can harm legitimate authors. “If a publisher uses a faulty detector, a writer’s career could be damaged by a false accusation,” the Guild warned.
A false-positive rate of 100% means the tool is no better than random chance — and arguably worse, because it creates a false sense of certainty.
Publishers, editors, and educators should treat AI detection results with extreme skepticism. No current tool can reliably distinguish human from AI text, especially on shorter or stylistically unique pieces.
What the Authors Guild Recommends
The organization advises against using AI detectors as the sole basis for any decision. Instead, they recommend:
  • Manual review by experienced editors or teachers who understand the writer’s style.
  • Transparency policies that require disclosure of AI use, rather than outsourcing judgment to a black-box tool.
  • Caution with contractual clauses that penalize writers based on detector results.
The Guild also plans to repeat the test with larger and more diverse text samples, and to push for industry standards around AI detection accuracy.
AI detectors are not ready for prime time. Two of the five tested tools performed perfectly on human writing, but two others failed on every single text. For authors, the safest approach is to assume all detectors can produce false positives and to never let a machine have the final word on authorship.
