Bun Ditches Zig for Rust in AI-Assisted Rewrite
The JavaScript runtime Bun has abandoned its original Zig codebase for Rust, leveraging AI to rewrite over one million lines of code in just 11 days. The move, assisted by Anthropic’s Claude and the code generation tool Fable 5, marks a dramatic shift in Bun’s architecture that aims to improve performance, maintainability, and ecosystem compatibility.
Bun’s creator, Jarred Sumner, announced the decision after determining that Rust’s memory safety guarantees, mature tooling, and larger developer community outweighed Zig’s advantages for the project. The rewrite was executed at unprecedented speed using AI-generated code, with Fable 5 outputting the bulk of the new Rust implementation under Claude’s supervision.
Why the Switch from Zig to Rust?
Performance and safety tradeoffs drove the decision. While Zig offered low-level control and fast compilation, Rust’s borrow checker and ownership model provided stronger compile-time guarantees against memory bugs.
Ecosystem maturity played a key role. Rust boasts a vast library of crates, extensive documentation, and a far larger talent pool than Zig. Bun’s maintainers concluded that long-term sustainability required aligning with the broader industry trend.
Interoperability with existing Node.js tools was another factor. Rust’s Foreign Function Interface (FFI) and WebAssembly support made it easier to integrate with JavaScript runtimes and native modules, reducing friction for developers.
How Claude and Fable 5 Executed the Rewrite
“We asked Claude to architect the modular structure and then fed the design into Fable 5, which generated the actual Rust code at scale.” — Jarred Sumner
The process combined human oversight with AI automation. Claude handled high-level design decisions, including module boundaries, API contracts, and error handling patterns.
Fable 5 then wrote over 1.2 million lines of Rust code in 11 consecutive days, translating Bun’s existing Zig logic into idiomatic Rust. The AI tool used a repository of training data from open-source Rust projects to ensure generated code followed best practices.
Manual review and testing followed each generation batch. Sumner reported that approximately 92% of the AI-written code passed integration tests without modification, with the remaining 8% requiring small patches or refactoring.
The Scale of the Operational Challenge
Eleven days of nonstop code generation demanded careful resource management. The team ran multiple Fable 5 instances in parallel on cloud GPU clusters, with Claude acting as a quality gate to flag suspicious or incorrect outputs.
Version control complexity arose from merging over 5,000 commits generated by the AI. Bun’s maintainers created a custom merge workflow that automatically resolved conflicts based on dependency graphs and symbol visibility.
“Without Claude’s ability to reason about the overall architecture, this would have been impossible,” Sumner noted. “The AI didn’t just write code — it understood the system’s requirements.”
Implications for Bun’s Future
Performance benchmarks are expected to remain comparable or improve. Rust’s LLVM backend offers similar optimization opportunities to Zig, and the rewrite allowed the team to eliminate several performance bottlenecks that had been hard to address in the original code.
Developer contributions should become easier. Rust’s popularity means more open-source contributors can submit pull requests without learning Zig. Bun’s GitHub issues tagged “good first issue” have already seen a spike in activity.
Stability risks remain. The AI-generated code has not undergone years of real-world testing. Sumner acknowledged that edge cases in file I/O, networking, and garbage collection may surface over time, requiring ongoing human patches.
What This Means for the AI-Assisted Coding Landscape
The Bun rewrite demonstrates that AI can now replace entire programming language foundations when paired with expert human oversight. Claude handled the design reasoning, while Fable 5 performed the grunt work of translation — a division of labor that could become standard for large-scale migrations.
Critics warn that over-reliance on AI-generated code introduces hidden technical debt. The 8% failure rate in Fable 5’s output may contain subtle logic errors that evade initial tests but cause production outages later.
Still, the speed of the rewrite — 11 days for a codebase that took years to build in Zig — signals a new ceiling for software evolution. “We basically fast-forwarded through a two-year rewrite,” Sumner concluded.
