Cloudflare's Clairic pulls data from documents faster and cheaper than LLMs
Cloudflare’s Clairic pulls data from documents faster and cheaper than LLMs
Cloudflare launches Clairic for document extraction
Cloudflare has released Clairic, a tool that pulls data from documents faster and cheaper than large language models. The product gives developers a lower-cost way to automate document processing.
Clairic is a dedicated extraction engine. It reads documents and returns data in a structured form, which makes it useful for automated workflows that need data from files.
What makes Clairic different
LLMs are general-purpose. They can summarize, reason, and answer questions across many contexts. But they are not always the most efficient choice for extracting data from documents.
Clairic is built for that specific task. Cloudflare says it can pull data from documents with lower cost and faster processing than an LLM.
  • Lower cost per document: The tool avoids the overhead that comes with full LLM inference.
  • Faster throughput: It is designed for high-volume document workloads.
  • Structured output: The extracted data can be fed directly into downstream systems.
The core argument is simple: document extraction does not always need a large language model. A specialized tool can handle the job with less compute.
Where Clairic fits in production
Document processing is a common bottleneck for AI workflows. Many teams use LLMs to read PDFs, scanned files, and forms. That works, but it can become slow and expensive as volume grows.
A specialized tool changes the math. If each document costs less to process, teams can automate more of the pipeline.
  • Extraction can happen before an LLM is needed: Clairic can pull data out of a document, and an LLM can be used only for tasks that need judgment.
  • Automation becomes practical at scale: Faster processing removes one of the main barriers to large document batches.
  • Costs stay under control: A purpose-built extraction tool is cheaper to run than a general-purpose model.
What Clairic doesn’t do
Clairic is not a replacement for LLMs. It is a data extraction tool, not a reasoning engine. If a task requires interpretation, summarization, or complex instructions, an LLM is still the right choice.
The opportunity is in using both. Clairic handles the repetitive part of document workflows. LLMs handle the harder cognitive parts.
Why this matters for developers
The AI market is shifting from “use one model for everything” to “use the right model for each job.” Clairic is a sign of that shift.
For developers, the benefit is clear. A faster and cheaper way to extract data from documents means more efficient automation.
It also means lower operational risk. A smaller, narrower tool can be more predictable than a general-purpose LLM.
  • Document-heavy products can scale better: Speed and cost improvements matter most at high volume.
  • Developers can reduce reliance on large models for simple tasks: That can lower total AI spending.
  • The tool is built for production automation: It is aimed at real workflows, not just experiments.
The bottom line
Cloudflare is making a practical bet. Many document workflows do not need the full power of an LLM. They need a fast, cheap, reliable way to turn documents into data.
Clairic is Cloudflare’s answer to that problem. It is faster and cheaper than LLMs for document data extraction, and it is designed for automation.
The key is to choose the right tool for the job. Use Clairic for extraction. Use an LLM for reasoning. That combination is likely to become the standard pattern for document-centric AI workflows.
