Context Files for Coding Agents: More Harm Than Help?
In the rapidly evolving landscape of AI-assisted software development, coding agents promise to automate complex engineering tasks. Tools like Devin, Cursor, and open-source models such as Claude 3.5 Sonnet or GPT-4o are increasingly tasked with resolving real-world GitHub issues. A common strategy to enhance their performance involves supplying extensive context files, such as READMEs, documentation, package.json, or entire repository structures. However, recent empirical analysis reveals a counterintuitive reality: these context files frequently fail to improve outcomes and can even degrade agent performance.
The Experiment: Testing Context in Real-World Scenarios
Researchers conducted a rigorous evaluation using the SWE-bench Lite dataset, a standardized benchmark comprising 300 hand-verified GitHub issues from popular Python repositories. This dataset demands agents to edit codebases autonomously to pass regression tests, simulating production-level software engineering challenges.
The study pitted leading coding agents against tasks under three conditions:
- Baseline: Agents receive only the issue description and access to the full repository via tools like file reading or search.
- Relevant Context: Addition of hand-selected, pertinent files (e.g., README.md, setup.py, requirements.txt).
- Full Repo Context: Provision of all non-code files (docs, configs, tests) up to a generous token limit.
Agents included proprietary systems like Devin and Cursor, alongside frontier models fine-tuned for coding: Claude 3.5 Sonnet, GPT-4o, and o1-preview. Each run enforced consistent prompting, tool usage (e.g., edit, read, grep), and sandboxed execution environments.
Striking Results: Context Often Backfires
The findings were unequivocal. Baseline performance without extra context files consistently outperformed augmented setups across most agents.
| Agent | Baseline (%) | Relevant Context (%) | Full Repo Context (%) |
| Devin | 13.3 | 10.0 | 6.7 |
| Cursor | 14.0 | 9.3 | 8.0 |
| Claude 3.5 Sonnet | 20.7 | 16.7 | 12.0 |
| GPT-4o | 33.3 | 25.3 | 20.0 |
| o1-preview | 28.0 | 22.0 | 18.7 |
On average, relevant context reduced success rates by 20-30%, while full repo context slashed them by 35-50%. Even top performers like GPT-4o saw their resolve rate drop from 33.3% to 20.0% with comprehensive context.
Qualitative inspection of agent traces uncovered patterns. With added context, agents exhibited:
- Distraction and Overanalysis: Models fixated on irrelevant details in READMEs or configs, derailing focus from the core issue.
- Token Saturation: Extra files consumed prompt capacity, truncating critical repository explorations via tools.
- Misalignment: Agents hallucinated changes based on outdated or tangential docs, introducing bugs absent in baseline runs.
For instance, in a task involving NumPy array handling, providing the full NumPy docs led Claude to propose deprecated APIs, failing tests that baseline tool-based searches avoided.
Why Does Context Hurt?
Several mechanisms explain this phenomenon:
Information Overload: LLMs excel at synthesis but struggle with noisy, voluminous inputs. Context files introduce redundancy; agents already access repos dynamically via tools, making static dumps inefficient.
Prompt Engineering Pitfalls: Boilerplate instructions to “use provided context” bias agents toward upfront files over iterative exploration. Baseline prompts encourage tool-first reasoning, aligning with agent architectures.
Model-Specific Behaviors: Smaller models suffered most from dilution, while larger ones like o1-preview showed resilience but still regressed due to increased error modes.
Benchmark Nuances: SWE-bench issues are self-contained; excessive context mimics real repos poorly, where signal-to-noise ratios vary.
Ablation tests confirmed causality. Stripping context restored performance, and selective omission of high-noise files (e.g., verbose CHANGELOGs) yielded marginal gains over full dumps.
Implications for Agent Design and Deployment
These results challenge prevailing wisdom in agentic workflows. Practices like RAG (Retrieval-Augmented Generation) for codebases or repo-wide context injection warrant reevaluation. Instead, developers should prioritize:
- Tool-Centric Prompts: Emphasize search, grep, and read tools over static context.
- Dynamic Retrieval: Implement relevance-ranked file fetching during inference.
- Context Pruning: If files must be included, curate surgically via heuristics (e.g., recency, centrality).
- Evaluation Rigor: Benchmarks must test context sensitivity to avoid over-optimistic claims.
For enterprise adoption, this underscores hybrid human-AI loops: agents shine on narrow tasks, but context overload amplifies brittleness.
Ongoing research explores mitigations, such as context summarization or multi-stage prompting. Yet, the core lesson endures: less can be more. Coding agents thrive on focused reasoning, unburdened by the full weight of repository lore.
