A recently disclosed vulnerability commonly referred to as “Java4Shell,” which affects Java-based applications and runtimes.
This CVE is a memory corruption vulnerability in the part of Java that handles Base64 operations, and it can allow an attacker to perform remote code execution.
Recommended actions for your environment
If you run any workloads that use Java, we strongly recommend that you:
1. Apply the mitigation. Either of the following Java startup options can be used:
- -XX:-UseBASE64Intrinsics (recommended): This option mitigates the exploit with minimal impact, since it only turns off the Base64 shortcuts.
- -XX:UseAVX=2: This option also mitigates the exploit, but it only works on x86-64 systems. Because it turns off AVX-512 instructions, it may reduce performance.
2. Update Java. Upgrade to a patched Java version as soon as one is available and validated in your environment.
3. Restart affected services. Java applications must be restarted for updates to take effect.
4. Review your inventory. Check for less obvious Java usage, such as third-party tools, embedded runtimes, and containers built on Java base images.
5. Make sure you system is uptodate.
Check if you’re affected: GitHub - gnoppix/CVE-2026-114938: Java4Shell CVE-2026-114938 Analysis and Lab · GitHub
Your Gnoppix Team
