DeepSeek Launches Free Coding Assistant to Rival Claude Code and OpenAI Codex
DeepSeek released DeepSeek Code, a free command-line coding tool that directly competes with Claude Code and OpenAI’s Codex. The tool handles large codebases, supports a 1 million token context window, and runs entirely from the terminal. It is available now with an API key.
DeepSeek Code executes commands, edits files, and answers programming questions. It is designed for developers working on complex projects.
The tool is free to use. Users only pay for API usage through DeepSeek’s platform.
What DeepSeek Code Does
DeepSeek Code is a terminal-based assistant. It does not require a GUI or browser plugin.
- Context window of 1 million tokens allows the model to process entire codebases in a single session.
- Command execution lets the AI run shell commands, install packages, and interact with the file system.
- File editing includes creating, modifying, and deleting files based on natural language instructions.
- Multi-language support covers Python, JavaScript, TypeScript, Go, Rust, and many others.
“DeepSeek Code can handle entire repositories, not just snippets. The 1M token window means it sees your whole project at once.” DeepSeek’s announcement
The tool uses the same underlying model as DeepSeek’s chat interface. It is optimized for code reasoning and generation.
How It Compares to Claude Code and OpenAI Codex
Claude Code and OpenAI Codex offer similar terminal-based functionality. DeepSeek Code differentiates itself on pricing and context length.
Claude Code by Anthropic costs $20 per month for Pro users. It has a 100K token context window.
OpenAI Codex powers GitHub Copilot and other tools. It requires a paid subscription. Context windows vary by model version.
DeepSeek Code is free to use. The API is priced at $0.14 per million input tokens and $0.28 per million output tokens. That is significantly cheaper than both competitors.
The 1 million token context window is a key advantage. Developers can load large monorepos without splitting files.
Performance and Benchmarks
DeepSeek Code claims strong results on coding benchmarks.
- HumanEval pass rate matches or exceeds Claude Code on similar tasks.
- SWE-bench (software engineering) score shows competitive performance on real-world bug fixing.
- Code editing accuracy measured across multiple programming languages.
The company published benchmark comparisons on its website. Results show DeepSeek Code outperforms Claude Code on some tasks and matches OpenAI Codex on others.
However, third-party verification is still pending. Independent reviewers have not yet validated all claims.
How to Get Started
Users need a DeepSeek account and an API key. The tool runs on Mac, Linux, and Windows via a terminal emulator.
- Sign up at platform.deepseek.com.
- Generate an API key under the billing section.
- Install DeepSeek Code using
pip install deepseek-code. - Run
deepseekin your project directory.
No credit card is required for the free tier. API usage is charged after exceeding the free allowance.
Limitations and Concerns
DeepSeek Code is built by a Chinese AI company. This raises data privacy questions for some developers.
- Data handling: The tool sends code to DeepSeek’s servers for processing. Local-only mode is not available.
- Regulatory risks: Trade secrets or sensitive code could be subject to China’s data laws.
- Model transparency: DeepSeek has not fully disclosed training data or model architecture.
“Be cautious when using DeepSeek Code with proprietary code. The tool uploads your project to their cloud for inference.” Security advisory from third-party analysts
The company states that data is encrypted in transit and not used for training. But independent audits are absent.
DeepSeek Code is a serious competitor in the AI coding assistant space. Its free pricing and massive context window give developers a low-cost option for large codebase management.
But privacy-conscious teams may prefer an offline alternative. Claude Code and OpenAI Codex offer more established security practices.
