Gnoppix on a Surface 3, no sound by default
Getting Linux running perfectly on Microsoft Surface hardware, especially a newer release like Gnoppix 26 usually requires a bit of extra legwork. The standard Linux kernel often lacks the specific drivers for the Surface’s Intel Smart Sound Technology (SST) and specialized hardware bridges.
The gold standard for fixing this is the linux-surface kernel project. Here is your step-by-step guide to getting your audio (and other features) working.
Step 1: Install the linux-surface Repository
The default Debian kernel doesn’t include the necessary patches for the Surface Book 3’s audio interface. You need to add the dedicated repository.
  1. Open your terminal and import the GPG key:
    wget -qO - https://raw.githubusercontent.com/linux-surface/linux-surface/master/pkg/keys/surface.asc \
    | gpg --dearmor | sudo dd of=/usr/share/keyrings/linux-surface-keyring.gpg
  2. Add the repository configuration:
    echo "deb [arch=amd64 signed-by=/usr/share/keyrings/linux-surface-keyring.gpg] https://pkg.surfacelinux.com/debian release main" \
    | sudo tee /etc/apt/sources.list.d/linux-surface.list
  3. Update your package list:
    sudo apt update
Step 2: Install the Kernel and Necessary Firmware
Now, install the custom kernel and the specific “secure boot” package if you have Secure Boot enabled in your BIOS.
  1. Install the kernel:
    sudo apt install linux-image-surface linux-headers-surface libwacom-surface
  2. Install the Surface DTX (for the Book’s clipboard detachment) and Touch/Audio firmware:
    sudo apt install surface-control iptsd
Step 3: Install the Intel Sof-Firmware
Surface Book 3 audio relies on the Sound Open Firmware (SOF). Debian is strict about “non-free” software, so you must ensure these are installed.
  1. Ensure you have non-free and non-free-firmware in your /etc/apt/sources.list.
  2. Install the firmware:
    sudo apt install firmware-sof-signed
Step 4: Fix the “Dummy Output” (The Audio Script)
Even with the kernel, the Surface Book 3 often needs a specific configuration to “wire” the Intel SST properly.
  1. Install the linux-surface-secureboot-moof package (if you use Secure Boot) to ensure the kernel loads.
  2. Reboot your machine. At the GRUB menu, ensure you select the kernel with “-surface” in the name.
  3. Check your audio. If it still says “Dummy Output,” you may need to install the alsa-ucm-conf package:
    sudo apt install alsa-ucm-conf
Step 5: Verify the Driver State
Once you have rebooted into the Surface kernel, check if the system sees your sound card:
Command Purpose
uname -a Verify you are running the surface kernel.
aplay -l List playback devices (should see Intel/Realtek, not just “dummy”).
`lsmod grep snd_sof`
Important Notes
  • Secure Boot: If your Surface won’t boot the new kernel, you likely have Secure Boot on. You will need to enroll the linux-surface MOK (Machine Owner Key) when the blue screen appears during the first reboot, or disable Secure Boot in the UEFI settings.
  • PipeWire vs Pulseaudio: Gnoppix uses PipeWire by default. If audio is still glitchy, install pavucontrol to see if the hardware nodes are just muted or set to the wrong profile (e.g., “Digital Stereo (HDMI)” instead of “Internal Speaker”).
