DeepMind Creates Global Forest Map with AI and Satellite Data
Google DeepMind has used AI and satellite imagery to create a global map of forests. The map provides a detailed, consistent view of tree cover across the entire planet. It is designed to support climate research, carbon accounting, and conservation planning.
Governments and scientists have long struggled to compare forest data across borders. This project gives them a single, open reference point.
Why the Map Was Built
Forests absorb roughly one third of human-caused carbon emissions. But the world lacks an accurate, up-to-date inventory of tree cover.
Existing global forest maps often have coarse resolution. They miss small forest patches and scattered trees in drylands. They also disagree with each other, making it difficult to assess changes over time.
DeepMind set out to solve that problem by applying machine learning to satellite data.
A New Standard for Counting Trees
Traditional forest maps are built from ground surveys or moderate-resolution sensors. Both have blind spots.
Ground surveys provide detailed tree measurements but cover limited areas. Moderate-resolution sensors miss small canopy gaps and thin woodlands.
DeepMind’s method combines the reach of satellites with the pattern recognition power of AI. The result is a continuous, standardized map of woody vegetation.
That consistency allows direct comparisons between countries and regions.
How the AI Works
Classifying Every Pixel
The project relies on images from the Sentinel-2 satellite mission. These images capture the Earth in multiple spectral bands.
The team trained deep neural networks to recognize tree canopies in those images. The model assigns each pixel a classification. It can distinguish dense forest, open woodland, and non-tree vegetation.
This classification is difficult to do by hand. AI makes it possible to process the entire planet consistently.
What the Map Reveals
The new map covers a larger area than earlier forest datasets. It also highlights tree cover in surprising places.
Open woodlands and farmed areas with scattered trees have often been overlooked. This map makes them visible for the first time. That has direct consequences for carbon accounting.
A high-resolution global baseline changes how countries can measure their forest resources. Accurate data is the foundation of effective climate action.
Why Accuracy Matters
Incomplete forest data distorts emissions estimates. Countries can underreport deforestation or overestimate their carbon sinks.
A reliable map helps environmental agencies detect illegal logging faster. It also helps researchers identify where restoration efforts are most urgent.
Validating the Model
The team cross-checked its AI output against independent datasets. Tests covered a range of climates and continents.
This validation ensures the model is not just repeating patterns from its training data. It gives confidence to researchers and policymakers who depend on the map.
Limits and Next Steps
Building a Timeline of Change
The current map is a snapshot. It does not yet chart forest change over time.
The model can be reapplied to historical satellite images. That would create a timeline of forest loss and regrowth.
Regular updates will be essential. With them, the map can become a true monitoring tool rather than a static baseline.
Key Facts
- Global forest map: DeepMind used Sentinel-2 satellite data to map tree cover across Earth.
- AI powered: Deep neural networks classified the images pixel by pixel.
- Climate impact: The data supports carbon accounting and deforestation detection.
- Open potential: The dataset is expected to serve researchers, governments, and NGOs.
