Google's PaperBanana uses five AI agents to auto-generate scientific diagrams
Google’s PaperBanana: Harnessing Five AI Agents for Automated Scientific Diagram Generation
Scientific research often demands meticulous visualization of complex concepts through diagrams, charts, and illustrations. Creating these visuals manually can be time-intensive, diverting researchers from core analysis and discovery. To address this challenge, Google researchers have introduced PaperBanana, an innovative AI system that automates the generation of high-quality scientific diagrams from natural language descriptions. By orchestrating five specialized AI agents, PaperBanana streamlines the process, enabling researchers to produce publication-ready figures with minimal effort.
The Architecture of PaperBanana
At its core, PaperBanana operates as a multi-agent framework built on advanced language models. The system ingests a textual prompt describing the desired diagram, such as “a bar chart comparing the accuracy of five machine learning models on the ImageNet dataset.” It then decomposes this task across five collaborative agents, each handling a distinct phase of the diagram creation pipeline. This modular design mimics human workflows, where ideation, data sourcing, design, rendering, and refinement occur sequentially yet interactively.
The five agents are:
  1. Planner Agent: This initial agent analyzes the user’s prompt to outline the diagram’s structure. It identifies key elements like chart type (e.g., line graph, scatter plot), axes, data requirements, labels, and stylistic preferences. Drawing from a knowledge base of scientific visualization best practices, the planner generates a detailed specification blueprint, ensuring the output aligns with academic standards.
  2. Retriever Agent: Responsible for sourcing relevant data, this agent queries integrated databases, public repositories, or simulated datasets. For instance, if the prompt references standard benchmarks like GLUE or SQuAD, it fetches precise metrics. When real data is unavailable, it employs synthetic generation techniques grounded in statistical distributions to produce plausible values, maintaining scientific integrity.
  3. Designer Agent: With data in hand, this agent crafts the visual layout. It selects optimal color schemes, scales, annotations, and compositions using heuristics derived from tools like Matplotlib or ggplot2 principles. The designer outputs a vector-based specification in a declarative format, such as SVG or a custom JSON schema, prioritizing clarity and accessibility.
  4. Renderer Agent: This agent translates the design into a pixel-perfect image. Leveraging graphics libraries and diffusion models fine-tuned for scientific visuals, it generates raster outputs at high resolutions suitable for papers (e.g., 300 DPI). It handles nuances like grid lines, legends, error bars, and 3D projections for specialized diagrams.
  5. Critic Agent: The final agent performs quality assurance. It evaluates the generated diagram against the original prompt using metrics like semantic similarity, aesthetic scores, and adherence to conventions (e.g., colorblind-friendly palettes). If discrepancies arise, it iterates by feeding feedback back to upstream agents, enabling multi-round refinement.
These agents communicate via a shared message bus, allowing dynamic adjustments. The entire process typically completes in under 60 seconds on standard GPU hardware, a stark improvement over manual creation.
Technical Implementation and Model Choices
PaperBanana is powered by Google’s Gemini family of multimodal models, with each agent fine-tuned for its role. The planner and critic leverage Gemini 1.5 Pro for reasoning depth, while the retriever integrates retrieval-augmented generation (RAG) with vector embeddings from datasets like PubMed figures and arXiv supplements. The designer and renderer employ vision-language models trained on millions of scientific images scraped from open-access papers.
A key innovation is the agent orchestration layer, implemented in LangGraph, which manages state, tool calls, and error recovery. Tools include Pandas for data manipulation, Plotly for interactive prototypes, and DALL-E variants for illustrative elements like molecular structures. Safety guardrails prevent hallucinated data in factual contexts, with users able to specify “use real data only.”
Evaluation benchmarks reveal impressive results. On a test set of 500 prompts from fields like biology, physics, and computer science, PaperBanana achieved 87% user satisfaction, outperforming baselines like GPT-4V (72%) and manual tools (baseline time: 30 minutes per diagram). Human experts rated outputs as “publication-ready” in 76% of cases, with strengths in consistency and speed.
Applications and Limitations
PaperBanana excels in generating diverse diagram types: bar and line charts for performance comparisons, heatmaps for correlations, flowcharts for methodologies, and schematics for hardware designs. In biology, it produces gel electrophoresis images or phylogenetic trees; in physics, Feynman diagrams or phase plots. Researchers at Google DeepMind have already integrated it into internal workflows, accelerating paper drafting.
However, the system has constraints. It struggles with highly domain-specific or proprietary data absent from its retriever’s corpus. Artistic or non-standard visuals (e.g., custom infographics) may require more iterations. Current support focuses on 2D diagrams, with 3D extensions planned. Ethical considerations include watermarking outputs to denote AI generation, preventing misuse in falsified research.
Future Directions
Google envisions PaperBanana evolving into a broader “PaperAgent” suite, incorporating agentic tools for full paper automation, from literature reviews to experiment design. Open-sourcing components could democratize access, fostering community contributions to agent behaviors and datasets. As AI visualization matures, systems like this promise to level the playing field, allowing scientists worldwide to focus on insights rather than ink.
This advancement underscores the transformative potential of multi-agent AI in scientific communication, bridging natural language and precise graphics seamlessly.
