Luac0re: New mast1c0re Exploit for All PS4 and PS5 Firmwares
Luac0re: New Mast1c0re Exploit Targets All PS4 and PS5 Firmwares
In a significant development for the PlayStation hacking community, renowned developer TheFloW has unveiled Luac0re, a novel kernel exploit leveraging the mast1c0re vulnerability. This breakthrough enables full system access on every known PS4 and PS5 firmware version, marking a pivotal advancement in console modding capabilities. Unlike previous exploits limited by firmware boundaries, Luac0re offers universal compatibility, potentially ushering in a new era of homebrew applications, custom firmware, and enhanced user customization for Sony’s popular consoles.
Background on Mast1c0re and Its Evolution
The foundation of Luac0re rests on mast1c0re, a well-documented kernel vulnerability first disclosed years ago. Mast1c0re exploits a flaw in the PlayStation kernel’s handling of specific data structures, allowing attackers to execute arbitrary code at the highest privilege level. Historically, mast1c0re served as the cornerstone for early PS4 jailbreaks, powering tools like the PPPwn exploit chain. However, its reliability diminished on newer firmwares due to mitigations and patches implemented by Sony.
TheFloW, a veteran in the scene known for contributions such as the WebKit exploits in browser-based attacks, has revisited mast1c0re with innovative refinements. Luac0re specifically targets the Lua interpreter embedded within the PS4 and PS5 systems. Lua, a lightweight scripting language, is integral to many console processes, including user interface elements and game loading mechanisms. By identifying a type confusion vulnerability in LuaC0re20—the Lua 5.4.6 variant used in recent firmwares—TheFloW crafted a precise ROP (Return-Oriented Programming) chain that reliably triggers mast1c0re.
This approach bypasses previous limitations by chaining a userland Lua exploit directly into kernel code execution. The result is a stable, firmware-agnostic entry point that does not rely on outdated browser vulnerabilities or hardware-specific quirks.
Technical Breakdown of the Luac0re Exploit
At its core, Luac0re exploits a vulnerability in the Lua virtual machine’s type handling. When malformed Lua bytecode is processed, it triggers a type confusion between userdata and table objects. This misinterpretation allows an attacker to overwrite critical memory regions, setting the stage for a controlled ROP gadget chain.
The exploit proceeds in several meticulously orchestrated stages:
  1. Initial Payload Delivery: The exploit is delivered via a specially crafted HTML page hosted locally or remotely. Users navigate to this page using the console’s built-in browser, which remains unpatched across all firmwares.
  2. Lua Bytecode Injection: JavaScript within the page invokes Lua execution through exposed APIs in the browser environment. The injected bytecode exploits the type confusion, leaking kernel pointers and establishing a read/write primitive.
  3. Mast1c0re Chain Activation: With primitives in place, the exploit pivots to mast1c0re. It constructs a ROP chain using existing kernel gadgets to disable SMEP (Supervisor Mode Execution Prevention) and SMAP (Supervisor Mode Access Prevention), allocate executable memory, and execute a loader payload.
  4. Payload Execution: Once kernel control is seized, a custom loader deploys modules for full jailbreak functionality, including kernel-level access for homebrew execution.
TheFloW has publicly released the source code on GitHub at TheOfficialFloW/LuaC0re20, complete with documentation, proof-of-concept payloads, and build instructions. Developers can compile the exploit using standard toolchains, ensuring reproducibility and community scrutiny.
Key technical highlights include:
  • Stability: Reported success rates exceed 95% across tested firmwares, attributed to deterministic primitives.
  • Firmware Coverage: PS4 from 1.00 to 12.02; PS5 from 1.00 to 10.01, encompassing the vast majority of deployed consoles.
  • No Downgrade Required: Operates on stock firmware without necessitating firmware downgrades or hardware modifications.
Implications for PS4 and PS5 Users
For PS4 owners, Luac0re revitalizes older systems on the latest firmwares, enabling installations of custom firmware like GoldHEN, backup game loading, and cheat engines. PS5 users, previously constrained by Sony’s aggressive patching, now gain equivalent capabilities, albeit with caveats for disc-based authentication in some scenarios.
This exploit democratizes access to console internals, fostering innovation in emulation, region-free playback, and performance tweaks. However, users must exercise caution: running unsigned code carries risks of instability, bricking, or voided warranties. Sony’s terms of service prohibit modifications, potentially leading to online ban enforcement via PSN checks.
Community responses have been enthusiastic, with rapid integrations into tools like PS4/PS5 payload injectors. Forums buzz with tutorials, though TheFloW emphasizes responsible use and credits prior researchers like Sleirsgoevy and SpecterDev for foundational work.
Deployment and Best Practices
To deploy Luac0re:
  • Clone the repository and build the HTML exploit.
  • Host it via a local HTTP server (e.g., using Python’s http.server).
  • Connect the console to the same network and access the page in the browser.
  • Follow on-screen prompts for payload selection.
TheFloW advises testing on non-primary consoles first and maintaining firmware backups. Future updates may address edge cases on ultra-high firmwares or Pro models.
In summary, Luac0re represents a masterful synthesis of Lua exploitation and mast1c0re chaining, solidifying TheFloW’s legacy while expanding modding horizons. As the scene evolves, expect derivatives and hardened defenses from Sony.
