Meta’s Muse Spark 1.1 outperforms GLM 5.2 in coding benchmarks while costing slightly less, according to the company’s latest benchmarks. The new model targets developers seeking a high-performance, cost-efficient alternative for code generation and reasoning tasks.
The Lede: What Changed
Muse Spark 1.1 beats GLM 5.2 on major coding tests including HumanEval and MBPP. Meta says the improvement comes from better training data and a refined architecture.
The model costs marginally less per token than GLM 5.2, making it attractive for teams running large-scale code generation pipelines.
Benchmark Results
Key performance numbers from Meta’s internal evaluation:
- HumanEval pass@1: Muse Spark 1.1 scores 82.7%, GLM 5.2 scores 78.9%.
- MBPP pass@1: Muse Spark 1.1 scores 74.3%, GLM 5.2 scores 70.6%.
- Multi-PL (multiple programming languages): Muse Spark 1.1 leads in Python, JavaScript, and C++.
The margin is narrow but consistent across all tested languages.
Pricing Comparison
Pricing is a critical factor for enterprise adoption.
- Muse Spark 1.1: $0.28 per million input tokens, $0.42 per million output tokens.
- GLM 5.2: $0.32 per million input tokens, $0.48 per million output tokens.
Savings add up for high-volume users, though the difference is less than 15% at current rates.
Meta positions this as a “cost-performance sweet spot” for teams that already use open-weight models and want to reduce inference bills without sacrificing accuracy.
Under the Hood
Muse Spark 1.1 uses a Mixture-of-Experts (MoE) architecture with 7 billion active parameters and 16 billion total parameters. GLM 5.2 uses a dense 13-billion-parameter design.
The MoE approach allows the model to activate only relevant expert sub-networks per token, reducing compute during inference. This explains the lower cost and faster response times.
Meta trained the model on a curated dataset that emphasizes code correctness, comment generation, and bug detection. The training set includes public repositories and synthetic examples.
Use Cases and Limitations
Developers can deploy Muse Spark 1.1 for:
- Code completion in IDEs
- Unit test generation and debugging
- Code review suggestions and refactoring
The model struggles with very long context windows (above 32K tokens) and sometimes produces incorrect imports for niche libraries. Meta recommends pairing it with a retrieval step for production use.
“Muse Spark 1.1 is not a replacement for top-tier proprietary models like GPT-4 or Claude 3.5 in complex multi-step reasoning, but it matches or beats open-source peers in coding tasks,” a Meta spokesperson said.
What This Means for Developers
The competitive landscape for open-weight coding models is heating up. Muse Spark 1.1 undercuts GLM 5.2 on price and edges ahead on accuracy. Teams that previously favored GLM due to licensing or cost may now reconsider.
Meta open-sourced the model’s weights under the same permissive license as previous Muse models, allowing fine-tuning and commercial use.
No major deployment changes are needed for teams already using Muse Spark 1.0, as the API and model structure remain backward compatible.
