New AI model called "Count Anything" does exactly what it says, and that's harder than it sounds
New AI Model Counts Anything in Images with Surprising Accuracy
Counting objects in a photo is deceptively difficult. A new AI model called Count Anything tackles that challenge head-on. It can tally up items like cars, cells, or screws with high precision, solving a problem that stumps most computer vision systems. The tool is now available for testing.
Why Counting Is a Hard AI Problem
Counting is not simple pattern recognition. Traditional object detectors like YOLO or SAM label and locate objects but do not inherently sum them up.
  • Counting requires spatial reasoning: The model must identify every instance without double-counting or missing occluded objects.
  • Scale variance is extreme: One photo might have 3 elephants, another 3,000 grains of rice. Models must handle both without retraining.
  • Density and clutter confuse standard AI: When objects overlap or are tiny, segmentation models fail. Count Anything appears to bridge that gap.
How Count Anything Works
The model uses a novel approach combining segmentation and regression. Instead of detecting each object with a bounding box, it outputs a density map that sums to the total count.
Users provide a prompt — either text or a click on an example object. The model then scans the image and returns a number.
“The key insight is that counting is fundamentally different from detection. You don’t need to know where every object is, just how many there are.” — from the research paper cited in the article.
Tests show the model performs well across synthetic and real-world datasets. It outperforms previous state-of-the-art counting models on benchmarks like FSC-147 and CARPK.
Real-World Applications
Accurate counting has high practical value across industries.
  • Manufacturing quality control: Count components on a conveyor belt without manual inspection.
  • Medical imaging: Count cells, bacteria, or tissue structures in microscope slides.
  • Wildlife monitoring: Estimate animal populations from drone or camera trap footage.
  • Retail inventory: Tally products on shelves with a single photo.
Limitations and Open Challenges
The model is not perfect. Performance drops when objects vary wildly in size or lighting conditions are poor. It also struggles with extreme clutter where objects are nearly indistinguishable from the background.
Developers plan to release an open-weight version. That would allow integration into custom pipelines, but no official release date has been set.
Count Anything represents a meaningful advance in computer vision. It solves a narrow but important task that most existing models handle poorly. For researchers and engineers working on visual counting, this tool could save hours of manual labeling and improve accuracy.
