New math benchmark reveals AI models confidently solve problems that have no solution
The rapid progress of large language models has sparked intense interest in evaluating their mathematical reasoning abilities. A recently introduced benchmark takes a distinctive approach by presenting models with problems that are provably unsolvable or contain inherent contradictions. Rather than measuring correct answers alone, the benchmark probes whether models recognize the absence of a solution and how confidently they assert an answer when none exists. This design exposes a critical gap between raw performance and genuine understanding, highlighting tendencies toward overconfidence that can undermine trust in AI systems.
The benchmark consists of a curated set of statements drawn from formal logic, number theory and combinatorics. Each item has been proven to have no valid solution within the standard axioms of mathematics. Examples include assertions that contradict known theorems, requests to find integer solutions to equations proven impossible by modular arithmetic, and prompts that ask for the largest element of an infinite set that lacks an upper bound. By construction, the correct response for every item is to indicate that the problem cannot be solved or that no answer exists. The evaluation therefore records two key metrics: the proportion of times a model explicitly states that the problem is unsolvable, and the average confidence score attached to the model’s output when it does provide a numerical or symbolic answer.
To assess a range of contemporary models, researchers ran the benchmark on several publicly available releases, including variants of GPT‑4, Claude 2, LLaMA 2 and open‑source alternatives such as Mistral. Each model received the same prompt formulation, which instructed it to reason step by step and to output either a solution or a declaration of impossibility. Confidence was extracted either from the model’s internal probability distribution over tokens or from an explicit confidence rating when the model was prompted to quantify its certainty. The experiments were conducted under identical temperature and sampling settings to ensure that variations stemmed from model capabilities rather than procedural differences.
The results reveal a striking pattern. Across all tested models, the frequency of correct “no solution” declarations remained low, often falling below 20 percent even for the largest parameter counts. When models did produce an answer, they frequently assigned high confidence scores to responses that were mathematically incorrect. For instance, GPT‑4 offered a numerical value for an unsolvable Diophantine equation in over 60 percent of trials, accompanying those answers with confidence estimates exceeding 0.9 on a normalized scale. Similar trends appeared for Claude 2 and LLaMA 2, though the absolute numbers varied. Notably, increasing model size did not substantially improve the recognition of impossibility; instead, larger models tended to generate more elaborate but still fallacious justifications for their erroneous answers.
These findings point to a systematic overconfidence in the models’ reasoning processes. Rather than detecting the logical inconsistency embedded in the prompt, the models appear to default to pattern‑matching strategies that generate plausible‑looking outputs. The confidence scores, which are intended to reflect calibrated uncertainty, fail to penalize the generation of false solutions, suggesting that current training objectives do not adequately enforce alignment with logical correctness. This misalignment poses risks for applications where reliance on AI‑derived mathematical conclusions could lead to erroneous decisions, especially in fields such as cryptography, engineering design or automated theorem proving.
The authors discuss several avenues for mitigating this behavior. One approach involves incorporating explicit unsolvable or contradictory examples into the training data, thereby teaching models to recognize when a prompt lies outside the realm of solvable problems. Another direction focuses on refining uncertainty estimation techniques, such as employing ensembles or Bayesian neural networks, to produce confidence scores that better correlate with actual correctness. Additionally, post‑hoc verification steps that invoke symbolic reasoning engines or proof assistants could serve as a safeguard, allowing the model’s output to be checked against formal correctness criteria before being presented to a user.
In conclusion, the new benchmark sheds light on a fundamental limitation of today’s AI systems: the tendency to answer questions with high confidence even when those questions have no valid answer. By exposing this gap between performance and genuine comprehension, the work underscores the need for training regimens and evaluation metrics that prioritize logical soundness over superficial fluency. Continued research into better calibration, richer training signals, and hybrid neuro‑symbolic architectures will be essential to build AI tools that users can depend on when tackling mathematically rigorous tasks.
