OpenAI researchers want to predict how often AI models will fail before launch
OpenAI researchers have developed a new method to predict how often AI models will fail before they are publicly launched. The system, called “pre-deployment failure prediction,” aims to forecast error rates by analyzing a model’s behavior during training, answering the critical question of when and why an AI system will malfunction before it reaches users.
The core breakthrough is a shift from reactive to proactive safety testing. Instead of waiting for failures to emerge in real-world use, the technique uses early training signals to estimate future error rates. This allows developers to identify high-risk models and potentially halt a launch, according to a paper published on the open-access platform arXiv.
How the Prediction System Works
The method relies on two key performance indicators. The first is “prevalence,” which measures how often a model produces a specific type of error during its training phase. The second is “generalizability,” which assesses whether the model’s ability to avoid errors continues to improve as it is trained on more data.
A high prevalence of errors, combined with poor generalizability, is a strong warning sign. If a model repeatedly makes the same mistakes and shows no improvement in avoiding them across different training scenarios, the system flags it as likely to fail at a high rate once deployed.
The researchers call this their “Proactive Failure Prediction” framework. It contrasts sharply with current industry standards, which typically rely on post-launch monitoring, red-teaming, or public bug reporting to catch failures after an AI system is already in use.
Implications for AI Safety and Deployment
This approach could fundamentally change how AI companies manage risk. By giving a clear, data-driven signal of expected failure rates before a product ships, it creates a new checkpoint for decision-makers. A bad prediction could justify delaying a launch, while a good one could provide confidence in releasing a model.
The method is designed for any type of AI model, not just language models. The researchers state it can be applied to any system where errors are defined, from image recognition to autonomous driving. This makes it a potentially universal safety tool.
“This is the first step toward a safety culture where you don’t just test after you build,” said one researcher involved in the study. “You predict the failure before you spend a cent on deployment.”
The system does not eliminate all risk, however. It cannot predict entirely new types of errors that a model might learn after launch. It also requires developers to have a clear, pre-defined definition of what constitutes a “failure” in their specific use case.
The Current State of AI Failure Monitoring
Most fail-safes today are backward-looking. Companies like OpenAI, Google, and Anthropic currently rely on internal red-teaming, external bug bounties, and public feedback loops. These methods are effective but are inherently reactive, catching problems only after they have occurred in the wild.
Pre-launch prediction offers a proactive alternative. It allows developers to see a “risk score” for a model before it ever interacts with a real user, potentially preventing a catastrophic rollout of an unsafe system. The research is still in its early stages, but it represents a significant pivot in safety engineering.
The method requires a high volume of training data to be accurate. For models with limited training examples, or those still in the very early stages of development, the predictions may be less reliable. The researchers are now working on methods to handle low-data scenarios.
The long-term goal is to make predictive safety a standard part of every AI launch. The team hopes their framework will be adopted by the entire industry, much like how software testing became standard before any product release.
