OpenAI shares new prompting tips for GPT-6.2 Astra and Sol to fix brief answers and unnecessary questions
OpenAI has published new prompting tips for GPT-6.2, Astra, and Sol. The guidance is designed to fix two common problems: answers that are too brief and follow-up questions that feel unnecessary.
The update matters because both issues slow down real work. A model that gives a one-line answer can force the user to reprompt. A model that asks clarifying questions when none are needed can interrupt a smooth workflow.
Why OpenAI changed the prompt guidance
OpenAI now says the problem often lies in the wording of the prompt. The same model can behave very differently depending on how the request is framed. The new tips are written for GPT-6.2, Astra, and Sol, and they focus on giving users clear ways to set boundaries.
The key prompting tips
  • Set the desired answer length. Tell the model how long the answer should be. A simple sentence such as “give a detailed answer” or “keep it short” changes the output.
  • Stop unnecessary questions. Instruct the model to make a reasonable assumption and continue. The guidance asks users to state this explicitly instead of letting the model default to clarification.
  • Define the output format. Mention the type of response you want. Lists, tables, bullet points, and paragraphs all produce different results.
  • Put the most important instruction first. The beginning of the prompt gets the most weight. Use it for length, question rules, and format.
  • Add context where useful. For Astra and Sol, context helps the model judge what level of detail is needed.
Fixing brief answers
The “brief answer” fix is straightforward. OpenAI’s guidance shows that open-ended prompts can produce short replies because the model does not know how much detail the user wants. The solution is to tell the model what “enough” means.
If you want examples, say so. If you want a summary first, say that. If you want the answer to include background, list it. This is not a trick. It is a direct instruction.
Reducing unnecessary questions
The second fix requires setting a rule for uncertainty. Many models default to asking a question when they detect missing information. The new prompting tips tell users to remove that default.
A prompt can include a line such as: “Do not ask for details. Make a reasonable assumption and proceed.” That one instruction can shift the model from a back-and-forth conversation to a single useful answer.
How to apply these tips
The best place for these instructions is at the top of the prompt. Put the length, question rule, and format before the actual task. That way, the model processes the constraints first.
OpenAI also suggests reviewing the output and adjusting the prompt when the result feels off. If an answer is too short, add an explicit length requirement. If the model asks too many questions, add a statement that makes the assumption rule clear.
The main takeaway is that these issues are fixable at the prompt level. The user does not have to accept short answers or pointless follow-up questions. A few clear instructions can change the behavior of GPT-6.2, Astra, and Sol.
The new guidance works through a simple pattern. State the desired length. Ban unnecessary questions. Define the format. Then let the model work. This pattern gives the user more control and makes the output more useful on the first try.
