OpenAI Reveals Prompting Tips for GPT-6 Astra: A Blocklist of Banned ‘Slop’ Words
OpenAI has released official prompting guidelines for GPT-6 Astra, including a strict blocklist of overused, low-quality “slop” words that degrade output quality. The guidance aims to help users craft precise prompts that avoid generic, buzzword-laden language.
The blocklist targets terms like “delve,” “navigate,” “embrace,” “elevate,” “unlock,” and “leverage” — words commonly found in AI-generated marketing copy. OpenAI warns these phrases produce robotic, formulaic responses.
Why OpenAI Banned These Words
The core reason is output quality control. Overused words create repetitive, predictable text that lacks originality. GPT-6 Astra is designed to generate fresh, context-aware content, but prompts loaded with these terms force the model toward default patterns.
OpenAI’s research found that prompts containing “delve” or “embrace” consistently produced responses rated lower in creativity and specificity by human evaluators. The blocklist acts as a guardrail against this degradation.
Key Insight: Removing “slop” words from your prompts is the single fastest way to improve output distinctiveness. The model performs better when you use concrete, plain language.
Essential Prompting Techniques for GPT-6 Astra
1. Use Direct, Action-Oriented Language
Replace vague verbs with specific commands. Instead of “Delve into the implications of AI ethics,” use “List three specific ethical risks in AI hiring tools and explain each in one sentence.”
Before: “Please elaborate on the transformative potential of quantum computing.”
After: “Explain how quantum computing breaks current encryption in 50 words.”
2. Define Output Structure Explicitly
GPT-6 Astra responds best to clear formatting instructions. Specify paragraph count, bullet point usage, or heading structure in your prompt.
- Best practice: “Write a 4-paragraph summary. Paragraph 1: the problem. Paragraph 2: the solution. Paragraph 3: risks. Paragraph 4: conclusion.”
- Avoid: “Discuss this topic openly.”
3. Set Negative Constraints
Tell the model what not to do. This is where the blocklist becomes a prompt tool.
- Example: “Do not use the words ‘delve,’ ‘navigate,’ ‘embrace,’ or ‘elevate.’ Write in plain, journalistic tone.”
- Result: Output avoids the slop pattern entirely.
Complete List of Banned ‘Slop’ Words
OpenAI’s official blocklist for GPT-6 Astra includes these categories:
- Generic verbs: delve, unlock, navigate, embrace, elevate, leverage, revolutionize, transform
- Inflated adjectives: groundbreaking, game-changing, unprecedented, innovative (when used without specifics), robust
- Filler nouns: landscape, paradigm, ecosystem, journey, roadmap
- Puffery phrases: “in this digital age,” “the future of X,” “at the end of the day,” “think outside the box”
Critical warning: Using any of these terms in a prompt may cause GPT-6 Astra to revert to lower-quality output modes. The model interprets them as a signal to generate boilerplate text.
How to Test Your Prompts Against the Blocklist
OpenAI recommends a two-step verification process before submitting prompts to GPT-6 Astra:
- Scan for slop words manually. Read your prompt aloud. If any phrase sounds like it came from a corporate press release, remove it.
- Run a test generation with and without the blocklist terms. Compare the specificity and depth of both outputs.
Users report that prompts scrubbed of “navigate” and “unlock” produce 30-40% more detailed responses on average, based on internal OpenAI testing.
Best Practices for Professional Use
Journalists and content creators should adopt these additional rules:
- Lead with the ask. Put your core question or instruction in the first sentence of the prompt.
- Limit to one objective per prompt. Split complex requests into separate conversations.
- Reward specificity. The more concrete the example in your prompt, the better the model mirrors it.
OpenAI emphasizes that GPT-6 Astra’s prompting system is not retroactive — past prompts using slop words will continue to generate poor output, but new prompts following these guidelines will immediately improve.
