OpenAI's Ted Sanders shares a rule of thumb for picking the right GPT-model
The Simple Rule for Choosing the Right GPT Model
OpenAI researcher Ted Sanders has a clear rule of thumb for picking a GPT model: match the model’s reasoning power to the task’s complexity. Use powerful models for deep reasoning. Use lighter models for everything else.
This guidance solves a common problem. Many developers default to the largest available model for every prompt. That habit increases cost, slows responses, and offers little benefit on simple tasks.
The Core Heuristic
The choice comes down to one question. Does the task require careful, step-by-step reasoning?
If yes, choose a reasoning-focused model. If no, choose a faster, cheaper model.
The smartest model is not always the best choice. The best model is the one that meets your quality bar at the lowest cost and latency.
Why the Rule Works
GPT models vary widely in capability and speed. Large models excel at complex logic, math, and multi-step planning. Small models handle everyday language tasks with ease.
Using a small model on a simple task gives fast, low-cost results. Using a large model on a basic task wastes time and money.
Using a small model on a complex task produces errors. Using a large model on a complex task provides accuracy. The rule helps you match the tool to the job.
How to Apply It
Start by testing your task on a lightweight model. Check whether the output meets your requirements. If it does, keep it. If it does not, move up to a more powerful model.
This test-first approach is practical and repeatable. It also keeps your system adaptable as new models arrive.
Choose a Lightweight Model When
  • The task is routine and well-defined, such as summarization, classification, or extraction.
  • Speed and cost are top priorities, and you need fast responses at scale.
  • The output quality is acceptable, even without deep reasoning.
Choose a Reasoning Model When
  • The task requires complex logic, such as advanced coding, math, or scientific analysis.
  • The answer needs multiple steps, and a single pass will not produce reliable results.
  • Errors are expensive, and you need the highest possible accuracy.
Why This Matters for Developers
The gap between model tiers is significant. Reasoning models require more compute and produce slower responses. Lightweight models are built for low-latency, high-throughput use cases.
Choosing correctly affects your infrastructure costs. It also shapes the user experience. A slow, expensive model on a simple chatbot is a bad fit.
This rule of thumb helps teams move faster. It removes guesswork. It gives product managers and engineers a shared framework for model selection.
Common Pitfalls
Many teams overthink model selection. They create elaborate frameworks when a simple heuristic works.
  • Never default to the biggest model for all requests. This is the most common and most costly mistake.
  • Do not ignore latency. Real-time applications need fast models.
  • Do not undervalue consistency. A smaller model that works reliably is better than a larger model that overpromises and underdelivers.
The Takeaway
Model selection is not about picking the smartest model. It is about finding the right balance between capability, speed, and cost.
Sanders’ rule of thumb gives you a clear starting point. Ask if the task demands deep reasoning. Answer honestly. Then choose accordingly.
This approach saves money, improves user experience, and keeps your AI system efficient as it grows.
