OpenClaw (formerly Clawdbot) and Moltbook let attackers walk through the front door
OpenClaw and Moltbook Discord Bots Expose Servers to Remote Attacks
Security researchers have uncovered critical vulnerabilities in two popular open-source Discord bots, OpenClaw (previously known as ClawdBot) and Moltbook. These flaws enable attackers to execute arbitrary code remotely, effectively granting them unrestricted access to affected Discord servers. The issues stem from inadequate validation of incoming webhooks, allowing malicious payloads to bypass security controls and compromise entire server infrastructures.
OpenClaw, a moderation and utility bot forked from the now-discontinued ClawdBot, boasts widespread adoption across thousands of Discord communities. Similarly, Moltbook serves as a versatile tool for server management tasks. Both bots rely on webhooks for handling external interactions, a common mechanism in Discord ecosystems for integrating third-party services. However, the implementation in these bots fails to properly sanitize or verify webhook data, creating a straightforward entry point for exploitation.
Vulnerability Breakdown in OpenClaw
The primary flaw in OpenClaw resides in its webhook processing logic. When a webhook payload arrives, the bot does not enforce strict checks on the content or origin of the data. Attackers can craft a malicious webhook that includes executable JavaScript or Node.js code. Upon receipt, OpenClaw evaluates this code within its runtime environment, leading to remote code execution (RCE).
Researchers demonstrated this by sending a webhook with a payload that spawns a reverse shell. The bot, running with elevated privileges typical for moderation tools, executes the shell command, providing the attacker with a command-line interface to the host system. From there, attackers can exfiltrate sensitive data, such as Discord tokens, server configurations, or user information stored in the bot’s database.
OpenClaw’s codebase, hosted on GitHub, reveals the vulnerability in the webhook handler module. The function responsible for parsing incoming requests lacks input sanitization, directly passing untrusted data to the evaluation engine. This oversight persists across multiple versions, affecting installations prior to the latest patches.
Moltbook’s Parallel Weakness
Moltbook exhibits a nearly identical vulnerability profile. Its webhook endpoint processes payloads without verifying their integrity or authenticity. An attacker needs only to know the webhook URL, which is often exposed through server logs, public repositories, or social engineering.
In testing, researchers injected a payload that leverages Node.js’s child_process module to run system commands. The bot’s event loop executes the code synchronously, amplifying the impact. Compromised Moltbook instances can propagate attacks to linked services, such as databases or other bots on the same host.
The shared architectural similarity between OpenClaw and Moltbook underscores a broader risk in open-source Discord bot development. Both projects inherit patterns from earlier bots like ClawdBot, where webhook flexibility prioritized functionality over security.
Exploitation in Practice
Exploiting these vulnerabilities requires minimal effort. Discord webhooks are HTTP POST endpoints, easily discoverable via bot documentation or decompiled source code. Tools like Burp Suite or custom scripts suffice to forge requests mimicking legitimate traffic.
Once inside, attackers gain persistence through cron jobs or modified startup scripts. They can also pivot to other servers if the bot manages multiple communities. Detection proves challenging, as the bots continue normal operations post-compromise, masking malicious activity amid routine moderation logs.
Jitware Labs, the firm behind the disclosure, responsibly notified maintainers. OpenClaw developers released version 2.5.0 with enhanced webhook validation, including signature checks and content whitelisting. Moltbook followed with a hotfix introducing rate limiting and payload parsing restrictions.
Mitigation Strategies
Server administrators should immediately update to patched versions or disable webhook features. Scanning for exposed webhook URLs using tools like Discord’s audit logs or external scanners is advisable. For high-security environments, migrating to audited alternatives like Carl-bot or Dyno, which implement robust input validation, offers a safer path.
Developers building Discord bots must prioritize secure webhook handling. Recommendations include:
  • Implementing HMAC-SHA256 signatures for payload authentication.
  • Using libraries like express-validator for input sanitization.
  • Running bots in sandboxed environments, such as Docker containers with seccomp profiles.
  • Logging all webhook requests with full payloads for forensic analysis.
Regular code audits and dependency scans via tools like Snyk or npm audit can prevent similar issues.
Broader Implications for Discord Ecosystems
These vulnerabilities highlight the front-door risks in plugin-based platforms. Discord’s 150 million-plus users rely on bots for essential functions, yet many lack enterprise-grade security. Open-source nature accelerates adoption but also propagation of flaws.
The ClawdBot lineage exemplifies this: Its shutdown prompted forks like OpenClaw, carrying forward unpatched code. Community-driven projects benefit from rapid iteration but demand vigilant security practices.
Incidents like these erode trust, potentially leading to stricter platform policies on bot approvals. Discord’s Verified Bots program already mandates security reviews for select tools, a model worth expanding.
In summary, OpenClaw and Moltbook’s webhook flaws serve as a stark reminder: Convenience endpoints can become attack vectors without proper defenses. Prompt patching and adherence to secure coding principles are essential to safeguard communities.
