Optima tackles AI benchmarking's biggest flaw by letting users test models against their own data
Optima Lets You Test AI Models on Your Own Data, Fixing Benchmarking’s Biggest Flaw
Generic AI benchmarks often mask real-world performance. Optima, a new benchmarking tool, solves that by letting users run tests on their own private data.
The tool was built by AI researchers and developers frustrated with standard leaderboards. Instead of relying on canned metrics like MMLU or HumanEval, Optima measures how a model performs on your specific tasks, documents, and business use cases.
Why Generic Benchmarks Fail
Standard benchmarks test general knowledge or common coding puzzles. But real-world AI deployment requires domain-specific accuracy.
  • Industry-specific data – A legal model needs to parse contracts, not trivia questions.
  • Proprietary formats – A medical AI must handle patient records, not generic text.
  • Privacy constraints – Sending sensitive data to public benchmarks is often impossible.
Optima tackles these gaps by running evaluations locally or in a secure environment. Users upload their own datasets, and the tool compares model outputs against ground truth or user-defined criteria.
How Optima Works
The process is straightforward. You choose a model from a supported list, upload your data, and run the evaluation.
  • Select models – Pick from open-source or proprietary models (GPT, Llama, Claude, etc.).
  • Upload your data – CSV, JSON, or plain text files with expected outputs.
  • Run evaluation – Optima computes accuracy, latency, cost, and other custom metrics.
Results are presented in a dashboard. You can compare multiple models side-by-side on the same dataset.
Many AI teams currently rely on gut feel or expensive manual testing. Optima provides a reproducible, automated alternative.
Key Features for Teams
Optima is designed for developers, data scientists, and product managers who need to make informed model choices.
  • Custom scoring functions – Define your own success criteria beyond simple accuracy.
  • Cost and latency tracking – See real trade-offs between model speed, price, and quality.
  • Privacy-first architecture – Data never leaves your infrastructure unless you choose a cloud evaluation.
  • Version control – Track how model performance changes over time or across retraining.
The tool supports both batch testing and real-time API calls. This allows teams to simulate production workloads before deployment.
A Shift Toward User-Centric Benchmarks
Optima reflects a broader industry move away from one-size-fits-all metrics. Companies increasingly demand proof that a model works on their actual problems, not just academic datasets.
  • Enterprise adoption – Businesses can now validate models on internal data without exposing it.
  • Open-source models – Developers can compare local models against cloud APIs fairly.
  • Continuous evaluation – Teams can rerun benchmarks after model updates or data changes.
The tool is currently in beta. Early users report catching performance gaps that standard benchmarks missed entirely.
“We found that Model A beat Model B on MMLU, but on our customer support logs, Model B was 40% better in accuracy and 30% cheaper per call.”
Optima strips away the noise of generic AI leaderboards. By putting your data at the center of evaluation, it delivers actionable, honest comparisons.
If you are choosing an AI model for a production system, testing on your own data is no longer optional. Optima makes it practical.
