PS4 Jailbreak Using Poops Exploit and BD-JB for Firmwares Up to 12.50
The PlayStation 4 scene has seen a significant advancement with the release of a new jailbreak method leveraging the Poops exploit combined with BD-JB. This development enables full console exploitation on firmwares ranging from 11.00 up to the latest 12.50, marking a major milestone for homebrew enthusiasts and custom firmware seekers. Unlike previous exploits limited to lower firmware versions, this solution bridges a critical gap, allowing users on more recent updates to access unsigned code execution, homebrew applications, and potential future custom firmware options.
Background and Exploit Chain Overview
The Poops exploit represents a sophisticated kernel-level vulnerability discovered and refined by prominent developers in the PS4 hacking community. It builds upon earlier webkit-based entry points but introduces a more stable and reliable chain for achieving code execution. Paired with BD-JB, a Blu-ray Disc Java-based loader, the method bypasses Sony’s security measures through a multi-stage process. BD-JB exploits the Blu-ray playback functionality inherent in the PS4, injecting Java bytecode that serves as the initial vector for privilege escalation.
This combination is particularly noteworthy because it supports a broad firmware spectrum without requiring downgrades or hardware modifications. Users on firmwares 11.00 through 12.50 can now proceed directly, provided they meet specific hardware and software prerequisites. The exploit chain initiates via a specially crafted Blu-ray disc or ISO image, which triggers the BD-JB loader. From there, the Poops payload is deployed, leading to full kernel access.
System Requirements and Compatibility
To successfully apply this jailbreak, the following conditions must be met:
- Firmware Versions: Exclusively supports 11.00 to 12.50. Consoles on lower or higher firmwares are incompatible without additional tools.
- Hardware: Standard PS4 models (CUH-10xx, CUH-11xx, CUH-12xx, CUH-20xx, CUH-21xx, CUH-70xx). Pro and Slim variants are fully compatible.
- Media: A Blu-ray drive is essential; USB-based methods are not supported in this release. Users need to burn the provided ISO to a compatible BD-R or BD-RE disc.
- Tools: Latest GoldHEN payload (version 2.4b17 or newer recommended), ftp server for file transfers, and a web browser for initial setup files.
Notably, this jailbreak is temporary and requires reapplication after each reboot. It does not install permanent custom firmware but enables persistent homebrew through repeatable exploitation.
Step-by-Step Implementation Guide
Implementing the jailbreak involves precise steps to ensure stability and avoid bricking risks. Always back up save data via PS4’s cloud or USB export feature beforehand.
Preparation:
- Download the official release package from the developer’s repository, including the BD-JB ISO, Poops exploit files, and GoldHEN payload.
- Verify file integrity using provided SHA-256 hashes to prevent corrupted downloads.
- Burn the BD-JB ISO to a Blu-ray disc using imaging software like ImgBurn or Rufus on a Windows PC.
Initial Boot and Exploit Trigger:
- Insert the burned Blu-ray disc into the PS4.
- Navigate to the Blu-ray player from the home screen. The disc should autoplay the BD-JB loader, displaying a confirmation prompt.
- Allow the Java applet to load, which transitions to the Poops exploit interface. A progress bar indicates kernel ROP chain initialization.
Payload Deployment:
- Upon successful exploitation (indicated by a green success screen), the console enters HEN (Homebrew Enabler) mode.
- Connect via FTP (default IP: 192.168.1.XX, port 1337) to transfer additional payloads.
- Launch GoldHEN from the web browser at http://ps4.local:1338 or the local IP address.
Verification and Usage:
- Test functionality with built-in tools like Enable Cheats, NoPSN, and Message Blocker.
- Install PKG files for homebrew apps such as RetroArch, webMAN MOD, and browser exploits.
- Reboot to confirm repeatability; the process takes approximately 2-3 minutes per session.
Key Features and Benefits
Once jailbroken, users gain access to an extensive ecosystem:
- Homebrew Execution: Run emulators, media servers, and custom apps seamlessly.
- Cheat Support: Apply game-specific trainers and mods via databases like NextGenCheats.
- Debug Tools: Enable Cobra mode for deeper system introspection.
- Stability Enhancements: Poops exploit reduces crash rates compared to older methods like PPPwn or LOD.
This method stands out for its firmware coverage, extending usability to consoles updated post-9.00 era exploits. Developers emphasize its robustness against Sony’s Hypervisor patches.
Risks and Best Practices
While groundbreaking, users must exercise caution:
- Online connectivity risks bans; disable PSN access and use LAN-only mode.
- Avoid firmware updates, as 12.51+ renders the exploit obsolete.
- Test on secondary accounts first to safeguard primary profiles.
- Community reports confirm 99% success rate on verified firmwares, with failures typically due to disc burns or USB hub interference.
Credits and Community Impact
This jailbreak is the culmination of efforts by key contributors: @Poopsical for the core exploit, @LightningMods for BD-JB integration, and @SiSTR0 team for GoldHEN refinements. The release has sparked widespread discussion on forums like PSXHAX and Reddit’s r/ps4homebrew, revitalizing the scene amid Sony’s tightening security.
Forums and Discord channels provide ongoing support, patches, and future updates. This tool democratizes PS4 ownership, empowering users to extend hardware lifespan through custom software.
