PS5-Linux-Hack expanded: Firmware 5.50 to 6.02 now compatible
Sony’s PlayStation 5 has seen a notable expansion of its Linux compatibility thanks to an updated exploit. Researchers have broadened the original PS5‑Linux hack so that it now works with system firmware versions ranging from 5.50 up to and including 6.02. Previously the exploit was limited to earlier releases, leaving owners of newer consoles unable to run a Linux environment without updating or downgrading their system software.
The core of the hack remains a WebKit‑based vulnerability that can be triggered through the console’s built‑in browser. By visiting a specially crafted web page, users can execute arbitrary code with sufficient privileges to launch a bootloader. This bootloader then loads a minimal Linux kernel and an initial ramdisk, allowing a full distribution to start. The process does not require any hardware modification; it relies solely on software manipulation of the existing firmware stack.
For the newly supported firmware range, the exploit chain has been adjusted to account for changes in the kernel’s memory layout and the browser’s sandboxing mechanisms. The developers updated the payload offsets and refined the return‑oriented programming (ROP) gadgets used to gain kernel execution. As a result, the same user‑friendly workflow that existed for firmware 5.00 and below now applies to the 5.50‑6.02 window.
Once the exploit is successfully triggered, the PS5 boots into a Linux environment that provides access to a standard userland. Users can install common utilities, compile software, and experiment with homebrew applications. However, the current implementation does not expose the console’s GPU to the Linux stack, meaning graphics‑intensive workloads must rely on software rendering or remain limited to 2D output. Additionally, certain hardware features such as the SSD’s NVMe interface and the DualSense controller’s advanced haptics are not yet fully functional under Linux, though basic input works.
The article outlines the exact steps required to reproduce the exploit. First, users must ensure their console is running one of the supported firmware versions. Next, they host the exploit HTML file on a local network‑accessible server or use a USB‑stick‑based web server to serve the page to the PS5’s browser. After navigating to the address, the browser displays a blank screen while the payload runs in the background. A successful exploit is indicated by the appearance of a login prompt or a small Linux shell overlay on the TV screen. From there, users can proceed with their preferred installation method, whether that involves copying a pre‑built rootfs via FTP, extracting a tarball over the network, or flashing an SD card image.
Security considerations are also discussed. Because the exploit relies on a browser vulnerability, updating the system to a firmware version beyond 6.02 will patch the issue and prevent the hack from working. Conversely, staying on an unsupported version leaves the console exposed to the same web‑based attack vector that enables the Linux boot. Users who wish to retain the ability to run Linux must therefore weigh the trade‑off between staying on a hack‑compatible firmware and receiving official security patches from Sony.
The developers emphasize that the exploit is intended for educational and home‑brew purposes only. They advise against using it for piracy, cheating in online games, or any activity that violates the PlayStation Network terms of service. The released code and instructions are shared under an open‑source license, encouraging the community to audit, improve, and port additional Linux distributions to the platform.
In summary, the PS5‑Linux hack has been successfully expanded to cover firmware releases 5.50 through 6.02. This update restores the possibility of running a free, open‑source operating system on a broader set of PlayStation 5 consoles, while highlighting the ongoing cat‑and‑mouse dynamic between console security measures and the home‑brew community. Users interested in trying the exploit should follow the detailed guide provided in the original article, keep their console within the supported firmware window, and remain aware of the functional limitations that currently exist.
