RL agents go from face-planting to parkour when researchers keep adding network layers
From Flailing Failures to Fluid Parkour: The Power of Network Depth in Reinforcement Learning Agents
In the realm of reinforcement learning (RL), where artificial agents learn complex behaviors through trial and error, a striking pattern has emerged: simply stacking more layers in neural network policies can catapult performance from clumsy collapses to acrobatic feats. Researchers from Physical Intelligence, Google DeepMind, and ETH Zurich demonstrate this in a recent preprint, showing how RL agents trained for basic quadruped locomotion evolve into parkour masters as network depth increases. What begins as face-planting on flat terrain transforms into vaulting over barriers and leaping across gaps, all without explicit task supervision.
The study focuses on sim-to-real RL for a quadruped robot, akin to Boston Dynamics’ Spot, navigating challenging environments. Agents are trained using model-free RL algorithms, specifically Proximal Policy Optimization (PPO), with policies represented as multilayer perceptrons (MLPs). The observation space includes proprioceptive data like joint positions, velocities, and orientations, plus height maps from a simulated LiDAR sensor for terrain awareness. Actions control joint torques, with a curriculum starting on flat ground and progressing to obstacle courses.
A core experiment varies policy network architecture: fixed width of 512 units per layer, but depths from 1 to 20 layers for both actor and critic networks. Training occurs in NVIDIA Isaac Gym simulations, scaling compute with depth—deeper networks demand more steps but yield outsized rewards.
Performance metrics tell a compelling story. Shallow networks (depth 1-2) achieve modest success rates on flat terrain, often resorting to inefficient crawling or stumbling. Success is measured by distance traveled without falling, normalized forward velocity, and energy efficiency. A depth-1 agent barely shuffles, frequently toppling due to poor balance and gait coordination.
As depth reaches 3-4 layers, agents transition to stable trotting, covering ground more reliably. By depth 5, they exhibit dynamic bounding gaits, even on uneven surfaces. The leap occurs around depth 8-10: agents not only walk faster but display emergent agility. Videos accompanying the paper illustrate this progression vividly—early agents flop like ragdolls, while deeper ones hurdle low obstacles with precise foot placement.
On a “parkour” course featuring gaps, walls, and ramps, shallow policies fail catastrophically: a depth-2 agent plunges into the first gap, while depth-1 cannot even approach. Depth-5 agents navigate half the course, but depth-12 policies conquer 95% of trials, employing strategies like mid-air adjustments and wall vaults. These behaviors emerge spontaneously; the reward function prioritizes velocity and upright posture, not acrobatics.
Why does depth matter so profoundly? The authors hypothesize that deeper networks enhance representational capacity for long-horizon planning and hierarchical control. Shallow MLPs struggle with high-dimensional function approximation, leading to myopic policies that prioritize immediate stability over sustained locomotion. Deeper hierarchies allow abstraction: low-level layers handle reflexes like foot clearance, mid-layers coordinate gait cycles, and top layers integrate terrain foresight.
Ablation studies reinforce this. Matching compute across depths by reducing steps for deeper nets still favors depth over width; a depth-12 network with halved width outperforms a wide, shallow one. Depth also improves sim-to-real transfer: a 12-layer policy deployed on a real Unitree Go2 quadruped robot trots smoothly outdoors, whereas shallower versions wobble.
Scaling curves plot success rate versus compute (measured in environment steps). Log-linear trends emerge, akin to language model scaling laws, suggesting RL benefits from predictable compute scaling via depth. Extrapolating, the researchers predict that 100-layer policies could enable humanoid parkour or manipulation.
Critically, these gains hold without bells and whistles like transformers or world models. Vanilla MLP policies suffice when scaled in depth, challenging assumptions that RL locomotion demands specialized architectures. The paper notes practical hurdles: deeper nets are sensitive to optimization hyperparameters, requiring careful learning rate scheduling and entropy bonuses to avoid collapse.
Visualizations underscore the transformation. Heatmaps of action distributions reveal deeper agents’ richer repertoires—high-torque jumps versus shallow nets’ timid shuffles. Gait analysis shows deeper policies favoring energy-efficient bounds over walks, aligning with biological quadrupeds.
This work echoes broader trends in deep RL, where scaling has unlocked AlphaGo, MuZero, and robotics milestones. Yet locomotion lagged, often relying on trajectory optimization or privileged information. Here, end-to-end RL closes the gap, hinting at a “Chinchilla-like” scaling regime for embodied AI: balance depth, width, and data.
For practitioners, the takeaway is clear: when designing RL policies, prioritize depth. Start shallow for baselines, then scale layers aggressively. The preprint provides code and models, inviting replication.
As RL agents vault from flops to flips, the path forward gleams: deeper networks may propel robotics toward human-level agility, one layer at a time.
