Stability AI launches Stable Audio 3.0 with up to six-minute tracks and open weights
Stability AI has unveiled Stable Audio 3.0, the latest iteration of its generative audio model designed to create music and soundscapes from textual prompts. This release builds on the foundation of its predecessors by extending the maximum length of generated audio to six minutes, a significant increase that allows for more elaborate compositions and longer-form sound design. The model’s architecture has been refined to maintain coherence over these longer durations, addressing a common challenge in sequential generation where early sections can drift from the intended theme as time progresses.
A central highlight of Stable Audio 3.0 is the decision to publish the model’s weights under an open license. By making the weights publicly available, Stability AI enables researchers, developers, and creators to inspect, fine‑tune, and deploy the model in a variety of environments without relying on proprietary APIs. This openness aims to foster community‑driven improvements and to lower the barrier for experimentation with AI‑generated audio in academic and commercial projects.
The model leverages a latent diffusion framework that operates on compressed audio representations, allowing it to synthesize high‑fidelity waveforms at 44.1 kHz stereo quality. Stability AI reports that the updated training regimen incorporates a larger and more diverse dataset of music, field recordings, and sound effects, which contributes to richer timbral variety and better adherence to user‑provided prompts. Conditioning mechanisms have also been enhanced, giving users finer control over aspects such as genre, instrumentation, mood, and temporal evolution through natural language descriptions.
Stable Audio 3.0 supports both unconditional generation, where the model produces audio based solely on learned priors, and conditional generation guided by text prompts. The conditional pathway has been optimized to respond to longer and more complex prompts, enabling detailed instructions such as “a slow‑building ambient pad with subtle granular textures that transitions into a gentle piano melody after two minutes.” The model’s ability to follow such nuanced directions over a six‑minute span demonstrates progress in long‑range dependency handling within the diffusion process.
In addition to the core model, Stability AI provides sample code and inference scripts that illustrate how to run Stable Audio 3.0 on consumer‑grade hardware. The release notes highlight that the model can be executed locally, which aligns with a growing emphasis on privacy‑preserving AI workflows. By keeping inference on‑device, users can generate audio without transmitting prompts or outputs to external servers, thereby retaining full control over their creative data.
The announcement also outlines the licensing terms associated with the open weights. While the model is accessible for research and non‑commercial use, Stability AI specifies that commercial exploitation requires a separate agreement. This approach seeks to balance the benefits of open collaboration with the need to sustain ongoing model development and support infrastructure.
Community reaction has been notable, with early adopters sharing examples of generated tracks that range from lo‑fi beats to orchestral excerpts, all extending beyond the typical thirty‑second limit seen in earlier versions. Feedback points to the model’s strength in maintaining thematic consistency across extended passages, a metric that Stability AI measured using internal similarity scores and subjective listening tests.
Stable Audio 3.0 represents a step toward more practical AI‑assisted audio production, where creators can rely on generative tools to draft full‑length arrangements, prototype soundscapes for multimedia projects, or explore novel sonic textures without the need for extensive manual composition. The combination of longer generation capacity, open weights, and improved conditioning offers a flexible platform that can be adapted to various workflows, from rapid ideation to deeper experimental research.
