‘Vibe Coding’ Is Becoming a Deal Breaker Test for Software Acquisitions
The “vibe coding” trend, where developers rely heavily on AI to write code without deep understanding, is emerging as a critical red flag in software company acquisitions. Investors and acquirers now see it as a litmus test for long-term code health and technical debt. The question is no longer just about what the software does, but how it was made and if anyone can actually fix it without an AI.
What Is “Vibe Coding”?
It is a term for a new development workflow where programmers use AI assistants like ChatGPT or Copilot to generate most of their codebase. Developers “vibe” by prompting the AI for features, then copy-pasting the output without fully reviewing or understanding the logic. This creates rapid output but often ghost-like code.
## The Core Problem: Phantom Code and Fragile Systems
The primary issue with vibe coding is the creation of “phantom code.” This refers to code that works in a narrow test case but fails unpredictably when real-world data or edge cases hit.
- No Deep Understanding: The developer did not write the logic, so they cannot debug it without the same AI.
- Hidden Dependencies: AI models often produce code with invisible, non-obvious library requirements that break on update.
- Massive Technical Debt: This style produces quick results today but creates a maintenance nightmare for tomorrow.
### The Critical Risk for Acquisitions
For an acquiring company, buying a vibe-coded product means buying a black box. You cannot assess actual code quality or security posture. The risk is existential:
“If the codebase was generated by AI, the team that built it cannot explain how it works. This makes due diligence impossible and post-acquisition integration a gamble.”
## How Acquirers Are Now Testing for It
Due diligence teams have developed specific techniques to flag vibe-coded assets. They are no longer just checking for bugs; they are checking for the style of the code.
### 1. The “Code Fluency” Interview
Acquirers now ask the founding developer to explain a critical code path blind, without an AI open. If the developer cannot articulate the logic flow, it signals “vibe code.” It is a deal breaker.
### 2. Homogeneity Analysis
Vibe-coded projects often share a distinct “AI signature.” The code is overly uniform in style, lacks human error patterns, and uses the same comment structure. It indicates one author, one AI, and zero human review.
### 3. The “Undo” Test
A key test involves breaking a small piece of test code and seeing how long the fix takes. Vibe-coded teams often freeze without their AI crutch; they cannot reason through a simple bug.
## The Bottom Line: Trust Is the Currency
Vibe coding is not a problem when building a prototype. It becomes a catastrophic liability when selling the company. The market is learning that software value is not in output, but in maintainability and deployability.
“The era of ‘ship fast and fix later’ is over. The acquirer now knows that ‘later’ might require a full rewrite. Vibe code is a liability, not an asset.”
## Key Takeaway for Software Builders
If you plan to sell your company, you must document and understand every line of AI-generated code. You must be able to teach your code to a human engineer without an AI. If you cannot, your exit strategy is at risk.
