Vulnerability in Smart Slider 3 WordPress Plugin Allows Low-Privileged Users to Read Server Files
A critical security flaw has been identified in the popular Smart Slider 3 WordPress plugin, enabling authenticated users with minimal privileges—such as subscribers—to access sensitive files on the web server. This local file inclusion (LFI) vulnerability poses significant risks to websites relying on the plugin, which boasts over 800,000 active installations. Security researchers disclosed the issue, highlighting how it bypasses standard access controls and exposes critical configuration data.
Discovery and Technical Details
The vulnerability, tracked as CVE-2024-48941, stems from inadequate input validation and sanitization in the plugin’s slider export functionality. Specifically, the affected endpoint in Smart Slider 3 versions up to 3.5.44 fails to properly restrict file paths provided by users during export operations. An attacker with a low-level account, like a subscriber, can manipulate the export parameters to traverse the server’s file system and retrieve arbitrary files.
In a proof-of-concept (PoC) demonstration, researchers showed how an attacker could prepend directory traversal sequences (e.g., “../../../”) to target files such as wp-config.php, which contains database credentials, API keys, and other confidential information. The flawed code resides in the plugin’s core handling of AJAX requests for slider exports, where user-supplied input directly influences the file inclusion process without sufficient checks.
The vulnerability requires authentication but no elevated privileges, making it accessible to basic registered users. Once exploited, the attacker receives the file contents encoded in the response, often in Base64 format, allowing easy decoding and analysis. This method evades common web application firewalls (WAFs) that might block unauthenticated or high-privilege attempts.
Severity and Impact
The National Vulnerability Database (NVD) has assessed this flaw with a CVSS v3.1 base score of 8.8, classifying it as “high” severity due to its exploitability and potential impact. Attackers gaining read access to server files can:
- Extract database credentials from wp-config.php, enabling full data exfiltration.
- Access .htaccess files to understand server configurations.
- Retrieve logs or other sensitive data that could facilitate further attacks, such as privilege escalation or ransomware deployment.
For organizations using Smart Slider 3 on production sites, the implications are severe. Compromised credentials could lead to complete site takeover, data breaches, or lateral movement within hosting environments. Given the plugin’s widespread adoption for creating responsive sliders and galleries, many small businesses, blogs, and e-commerce sites remain exposed.
Affected Versions and Exploitation Prerequisites
All versions of Smart Slider 3 prior to 3.5.45 are vulnerable. The plugin, developed by Nextend, integrates seamlessly with WordPress for dynamic content creation but inadvertently introduced this flaw in its export feature. Exploitation demands:
- A valid WordPress account with subscriber-level access.
- The Smart Slider 3 plugin installed and active.
- Direct interaction via the WordPress admin or frontend interfaces supporting exports.
No remote code execution is involved, but the LFI serves as a potent initial access vector. Researchers noted that the issue persisted despite prior security audits, underscoring the challenges in securing complex plugins.
Remediation and Best Practices
Nextend promptly released version 3.5.45, which patches the vulnerability by implementing strict path validation, whitelisting allowed directories, and sanitizing user inputs before file operations. Site administrators should:
- Update to Smart Slider 3 3.5.45 or later immediately via the WordPress dashboard.
- Review user roles and revoke unnecessary accounts, especially subscribers who do not require plugin access.
- Scan logs for suspicious export requests matching the PoC patterns.
- Employ security plugins like Wordfence or Sucuri for ongoing monitoring and virtual patching.
As a preventive measure, organizations are advised to limit plugin installations to trusted sources, enable automatic updates, and conduct regular vulnerability scans using tools like WPScan. Disabling direct file access through server configurations (e.g., via .htaccess) can mitigate residual risks.
Broader Implications for WordPress Ecosystem
This incident highlights ongoing security challenges in the WordPress ecosystem, where third-party plugins extend functionality at the cost of potential attack surfaces. With millions of sites powered by WordPress, timely patching remains crucial. Security firms urge plugin developers to prioritize secure coding practices, including input validation at every layer and comprehensive fuzzing for file-handling features.
Researchers who uncovered the flaw responsibly disclosed it to Nextend, adhering to standard disclosure timelines. The vendor acknowledged the report and deployed the fix within days, demonstrating effective collaboration.
In summary, while the vulnerability is straightforward to exploit, swift updates eliminate the threat. Website owners must act promptly to safeguard their assets against this and similar risks.
